This Arducam IMX219 camera module is mainly designed for NVIDIA® Jetson Board and also can be used on other hardware like ARM, DSP, FPGA, etc. The highlight of this camera is its wide field of view.
| Image Sensor | IMX219 |
| Still Resolution | 8 Megapixels |
| Video Modes | NVIDIA Jetson Orin NX/Orin Nano/AGX Orin: 3280x2464@21fps, 3280x1848@28fps, 1920x1080@30fps, 1640x1232@30fps, 1280x720@60fps |
| Sensor Resolution | 3280 × 2464 pixels |
| Sensor image area | 3.68 x 2.76 mm (4.6 mm diagonal) |
| Pixel Size | 1.12 µm x 1.12 µm |
| Optical Size | 1/4" |
| Focus Type | Fixed Focus |
| Focal Length | 0.76mm |
| F.NO | F2.1 |
| Field of View(FOV) | 220°(H) |
| Lens Mount | M12 Mount |
| Camera Board size | 25 x 24 mm |
| Peaking Current | 300mA |
The camera can be used on compute module CM3, CM3+, NOT compatible with Raspberry Pi 3B/B+.
This camera is released for the official NVIDIA® Jetson™ Developer Kit, and it does not guarantee to support other third-party boards.
