Arducam IMX219 Camera Module with fisheye lens, drop in replacement for Raspberry Pi V2 and Nvidia Jetson Camera
Arducam Pan Tilt Camera Bundle for Nvidia Jetson Xavier NX/Nano, 2 Two-DOF Platforms with 8MP IMX219 Cameras, with PTZ Control Board
Arducam IMX219 Camera Module with fisheye lens for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0287
  • More Than HD: This camera adopts 1/4” 8 Megapixel IMX219 sensor for sharp image, Max. still resolution is 3280 x 2464 pixels.
  • Wider Angle of View: This camera module has 220°(H) wide-angle M12 Lens, which provides a much wider Field of View compared to the stock lens on V2 camera module.
  • IR Sensitivity: Integral IR filter, visible light only; Focal Length: 0.76 mm
was $29.99 Special Price $25.99
This Arducam IMX219 camera module is mainly designed for NVIDIA® Jetson Board and also can be used on other hardware like ARM, DSP, FPGA, etc. The highlight of this camera is its wide field of view.
★KERNEL CAMERA DRIVER USED
  • Sony 8MP IMX219 Sensor
  • Optical Format: 1/4 inch
  • Data Format: RAW8/RAW10
  • Lens part number:M32076M20
  • EFL: 0.76mm
  • F.NO: 2.1
  • Focus Type: Fixed Focus
  • View Angle: 220(H)
  • Interface: MIPI CSI-2 2-lane/4-lane
  • IR Sensitivity: Integral IR Filter, visible light only
Image Sensor IMX219
Still Resolution 8 Megapixels
3280x2464@21fps, 3280x1848@28fps, 1920x1080@30fps, 1640x1232@30fps, 1280x720@60fps
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 0.76mm
F.NO F2.1
Field of View(FOV) 220°(H)
Electrical & Mechanical
Camera Board size 25 x 24 mm
Peaking Current 300mA
  • 1pcs Arducam IMX219 Camera Module with fisheye lens for Jeson Board and Raspberry Pi  Compute Module
  • 1pc 15cm 22-22pin FPC cable
  • 1pc 15cm 15-22pin FPC cable
The camera can be used on compute module CM3, CM3+, NOT compatible with Raspberry Pi 3B/B+.
This camera is released for the official NVIDIA® Jetson™ Developer Kit, and it does not guarantee to support other third-party boards.
IMX219 – 8MP Camera
2 comments
