Discover the Arducam all-in-one AI camera kit, powered by Raspberry Pi 5. This kit includes the official Raspberry Pi 5, AI Camera, and a durable case for quality performance.
With Sony’s IMX500 vision sensor, the Raspberry Pi AI Camera makes it easy to create visual AI applications. It’s seamlessly integrated RP2040, allowing users to deploy neural network firmware effortlessly.
Arducam’s kit comes ready with a preloaded SD card, eliminating setup time. Its specialized cooling system ensures stable AI performance, even during intensive tasks.
Raspberry Pi IMX500 AI Task Applications
| Image Sensor | |
| Sensor | Sony IMX500 |
| Still Resolution | 12.3 Megapixels |
| Color Filter Type | Color |
| Shutter Type | Rolling |
| Optical Size | 1/2.3" |
| Output Format | Image (Bayer RAW10), ISP output (YUV/RGB), ROI, metadata |
| Pixel Size | 1.55 µm x 1.55 µm |
| Sensor Active Area | 4056(H) × 3040(V) |
| Frame Rate | 2×2 binned: 2028×1520 10-bit 30fps Full resolution: 4056×3040 10-bit 10fps |
Lens |
| Focus Type | Manual adjustable focus |
| FOV | 78±3°(D)×66±3°(H)×52.3±3°(V) |
| Lens Mount | Stock Lens |
| F.NO | F1.79 |
| E.F.L | 4.74mm |
| Focus Range | 20 cm – ∞ |
| Operating Temp. | 0°C to 50°C |
| Power Requirements | Max 7.5W |
| Camera Board Size | 24 × 25 mm |
| Overall Size | 99×70×37 mm |
| Supported OS | Bookworm |
| Supported Platform | Raspberry Pi 5 |
