Arducam CS1808ZM06 CS-Mount Lens for Raspberry Pi HQ Camera, 8mm Focal Length with Manual Focus
LN250
  • It Just Works – No lens shading, no dark corners, decent image quality, mount the lens and use it.
  • The Wise Alternative – Another cost-effective choice that adds up to you Raspberry Pi High Quality Camera Module, with 8mm focal length and manual focus
  • Key Specs – 50 degrees Horizontal Field of View (HFoV), 1/1.8″ Lens Optical Format, F/1.2 large Aperture, with Dimension: Φ28×28mm, Weight: 55.6g.
  • Qualified Arducam – Arducam has been selecting and testing CS-mount lenses for the Raspberry Pi cameras since the V1 camera era. Check B0032 if you want a 5MP Pi camera with CS Lens, and check B0153 for the 8MP Pi cameras with CS lenses.
  • Check Arducam CS-Mount Lens Kit here: LK004
$16.99
In order to meet the increasing demands of the lens to work with Raspberry Pi High Quality Camera or other larger optical size cameras, Arducam selected and tested a wide range of lenses on RPI HQ cameras. This 1/1.8″ optical format CS-Mount Lens is excellent for RPI HQ Camera, with 8mm focal length and F1.2 large aperture. It's now much easier for you to get the best lens you'll need, and we will keep the lens list growing in the near future. Without lens shading, no dark corners, decent image quality, it just works. It is another cost-effective choice that adds up to you Raspberry Pi High Quality Camera Module.What’s more, if off-the-shelf optical solutions don't meet your needs, Arducam offers end-to-end custom camera and lens design services to help you turn your ideas into real products. From early concept to mass production, we work closely with you to tailor an imaging solution to meet your unique technical requirements and product goals.
Optical Specs
Focal Length 8mm±5%
Optical Format 1/1.8''
Aperture F1.2±10%
35mm Equivalent Focal Length for RPI HQ Camera 44mm
FOV(on Raspberry Pi HQ Camera) 80°(D)x50°(H)x30°(V)
Wavelength Coverage 420~1000nm
Lens Construction 6G
Mechanical Specs
Mount CS-Mount
M.O.D 0.3M
BFL 12.53mm
Weight (Net) 55.6g
Control Specs
Iris Operation Fixed
Focus Operation Manual
Zoom Operation Zoom Operation
Temperature range (Operating) -4°F-176°F (-20°C to +80°C)
Certification RoHS
  • 1 x 1/1.8" CS-Mount 8mm Focal Length lens for Raspberry Pi Cameras
