Arducam 5MP OV5647 Camera Module Motorized IR-CUT Filter for Daylight and Night vision for Raspberry Pi
Arducam 5MP OV5647 Motorized Focus Camera Sensor for Raspberry Pi
Arducam 5MP OV5647 Camera Module with CS mount Lens for Raspberry Pi 5/4/3B+/3
B0032
  • An Improvement of Standard Pi Camera: With the CS mount lens, you can get a bit more clarity, focus, and the ability to change the lens, will fit many lenses with this mount type, telephoto, fish-eye, or other M12 lenses
  • Works Flawlessly: The camera can be installed on the Rasparian OS as a Raspberry Pi camera. You can use libcamera apps to capture images
  • Customization Service: please contact [email protected] if you want to 8MP pi camera modules with CS mount lens.
was $29.99 Special Price $22.99
In order to meet the increasing need of Raspberry Pi compatible camera modules. The ArduCAM team now released a revision C add-on camera module which is fully compatible with official Raspberry Pi board. It optimizes the optical performance than the previous Pi cameras, and give user a much clear and sharp image. Also it provides the FREX and STROBE signals which can be used for multi-camera synchronize capture with proper camera driver firmware.
It attaches to Raspberry Pi by way of one of the two small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was designed especially for interfacing to cameras.
The camera is connected to the BCM2835/BCM2836 processor on the Pi via the CSI bus, which travels along the ribbon cable that attaches the camera board to the Pi.
  • Cellular phones,PDAs,Toys
  • Home security system
  • monitoring Octoprint 3D printer
  • PC multimedia
  • Digital still cameras,etc.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
IR Sensitivity Integral IR Filter
Focus Type Manual
Lens Type CS Lens
Peak Current 300mA
  • 1pcs Camera Board /w CS mount Lens(LS-2717CS) fully compatible with official Raspberry Pi Camera board
  • 1pcs 15cm 15-15 pin FPC cable
  • 1pcs 15cm 15-22 pin FPC cable
  • Raspberry Pi is not included in the package
  • The Camera Lens for Raspberry Pi Camera Board is LS-2717CS
  • Please feel free to contact [email protected] no matter what problems you have with the camera
    Raspberry Pi 5 √ √
User guide.pdf
3D drawing.step
Rev.C OV5647 Camera for Raspberry Pi Improves the Optical Performance
In order to meet the increasing need for Raspberry Pi compatible camera modules. The ArduCAM team now released a revision C add-on camera module for Raspberry Pi which is fully compatible with the official one. It optimizes the optical performance than the previous Pi cameras, and give the user a much clear and sharp image. […]
3 comments
Selection Guide
Edit
