Arducam 1.3MP MT9M001 Monochrome HD CMOS Camera Module M12 Mount 6mm Lens
Arducam 10MP MT9J001 Monochrome CMOS 1/2.3
Arducam 10MP MT9J001 Monochrome CMOS 1/2.3" Camera Module
Arducam 9MP MT9N001 Color Arducam CMOS 1/2.3-Inch Camera Module
B0098
Parallel camera interface.
$39.99
The MT9N001 camera module features DigitalClarity—Micron’s breakthrough low-noise CMOS imaging technology that achieves near-CCD image quality (based on signal-to-noise ratio and low-light sensitivity) while maintaining the inherent size, cost, and integration advantages of CMOS. 1/2.3" 9MP (3488 x 2616) CMOS color rolling shutter with global reset release camera module MT9N001. World-Class 1.75μm Pixel Sensitivity, Produced on Aptina’s world-class 1.75μm pixel with Aptina A-Pix technology, this high-resolution, highly sensitive compact sensor is perfect for DSC/DVC designs. Improved Low Light Performance Equivalent level as CCD sensor to support DSC applications. Preprocessing Features, including resampling for sub-sampled video and 2D defect correction, provide improved image quality.
  • 1/2.3" optical format
  • RGB Bayer pattern
  • 9MP 3488 x 2616 MT9N001 sensor
  • 1.75 x 1.75 um Pixel size
  • 9.7fps at full resolution
  • 0.44V/lux-sec responsivity
  • 62.7dB dynamic range
  • single 3.3V power input
  • Parallel camera interface
  • Default M12 mount 4.2mm LS-18023 lens
  • Digital video cameras
  • Digital still cameras
  • Industrial camera
  • Medical camera
  • Microscopy camera
  • UAV camera
  • 1pcs Arducam CMOS MT9N001 1/2.3-Inch 9MP Color Camera Module
  • NOTE: Please note that camera module only can be used together with Arducam USB shield.
    Please check the following link: http://www.uctronics.com/arducam-usb-camera-shield.html
User guide.pdf
Application note.pdf
Arducam USB3.0 Camera Shield
Github
ArduCAM/RaspberryPi
