[Discontinued] HM0360 VGA CMOS Monochrome Camera Module (NoIR) for RP2040 & Arduino-Arducam
[Discontinued] Arducam 190 Degree Fisheye 1/2.3
[Discontinued] Arducam 190 Degree Fisheye 1/2.3" M12 Lens with Lens Adapter for Raspberry Pi High Quality Camera
[Discontinued] 5-50mm Varifocal Lens USB Camera, 1080P@30fps WDR Webcam with 1/2.7" HD CMOS AR0230 Sensor for Computer, Laptop, Desktop-Arducam
B0356
Discontinued, check alternative item B0203, B0438.
$99.99
Arducam 5-50mm Varifocal Lens USB Camera, 1080P@30fps WDR Webcam with 1/2.7" HD CMOS AR0230 Sensor for Computer, Laptop, Desktop
  • HD 1080P Webcam: This USB camera adopts a high-quality COMS AR0230 Color sensor for sharp image and accurate color reproduction. Max resolution: 1928X1080, High frame rate 1080P@30fps, Compression format: MJPG / YUY2; Saturation, Contrast, White balance adjustable.
  • 5-50mm Optical Zoom: 5-50mm varifocal lens with an IR-cut filter@650nm provides a wide field of view from 40° to 8° by adjusting the focal length, giving you different sizes of images and scene ranges.
  • HDR & WDR: Up to 96dB wide dynamic range with high frame rate 1080P@30fps, this webcam produces extraordinarily clear, sharp digital pictures, and its ability to capture both continuous video and single frames makes it the perfect choice for a wide range of applications.
  • Plug & Play: Ready to use, this camera bundle comes with a metal case and mini tripod, just connect to a PC computer, laptop, or desktop with a USB cable, no need to install any driver software, allowing you easily take it everywhere.
  • Applications: UVC-compliant, widely compatible with Mac OS, Windows 7, 8, 10 /Android/ Linux. Highly recommended for the video surveillance system, live streaming, video conference, dashcam, and other video vision applications need high frame rates with high resolution.
SPECS
- Sensor: 1/2.7” AR0230
- Resolution: 1928(H) x 1088(V)
- Data Format: MJPG/YUY2
- Frame Rate: MJPG 30fps@1080P/720P/1280 x 1024/800 x 600/640 x 480; YUY2 5fps@1080P/720P; 20fps@800 x 600/960 x 540; 30fps@640 x 480
-Field of View (FOV): 40°-8°
- Lens Mount: CS
- Focal Length: 5-50mm
- Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
- System Compatibility: Windows, Linux, and Mac with UVC
Power
-Power Supply: USB powered 5V
-Working Current: MAX 300mA
Physical
-Operating Temp.: -4°F~158°F (-20°C~+70°C).
-Dimension: 50mmx50mmx80mm
-Cable Length: default 6.56ft (2M)
Manual.pdf
