Arducam 12MP IMX708 Autofocus 120°(DFOV)  Camera Module 3 with HDR Mode and PDAF Function for Raspberry Pi
Arducam 640x512 12μm 60Hz High-Speed USB Thermal Imaging Module with 9.1mm Lens & Precision Temperature Measurement
Arducam 640x512 12μm 60Hz Analog CVBS Thermal Imaging Module, Ultra-Low Latency Infrared Camera with 9.1mm Lens for FPV, Security & Industrial Monitoring
B0667
  • 640×512 High Resolution: Delivers high-definition thermal video via standard CVBS (Analog) signal for seamless integration with monitors and analog transmitters.
  • Real-Time 60Hz Fluidity: High frame rate ensures zero-lag, smooth imaging, which is critical for high-speed tracking, UAV piloting, and dynamic security.
  • Next-Gen Image Sensor: Features a cutting-edge 8~14μm spectral response detector, providing superior detail and longer detection range in a miniaturized form factor.
  • Ultra-Low Latency: Unlike digital/USB modules, the analog output provides near-instantaneous thermal feedback, ideal for FPV drones and mission-critical operations.
  • Rugged & Expandable: A compact 21x21x34.48mm build with support for multiple lens options (9mm to 50mm) to suit various field-of-view requirements.
$0.00
VOLUME PRICE
Arducam 640x512 60Hz Analog CVBS Thermal Imaging Module, Ultra-Low Latency Infrared Camera with 9mm Lens for FPV, Security & Industrial Monitoring.
Equipped with a self-developed 640x512 core, this module delivers professional-grade thermal sensitivity in a lightweight 24.5g package. Its 60Hz refresh rate eliminates the "stuttering" effect found in many thermal cameras, making it a top choice for automotive night vision, FPV drone racing, and industrial hot-spot monitoring. With its "White Hot" pseudo-color mode and precision temperature measurement capabilities, the module provides a clear, intuitive thermal map of any environment, day or night.
  • FPV & UAV Piloting: Lightweight, zero-latency thermal feed for night-time drone navigation and search & rescue.
  • Analog Security Systems: Easy upgrade for existing CCTV infrastructures to add thermal sensing capabilities.
  • Automotive Night Vision: Real-time obstacle and pedestrian detection for vehicle safety systems.
  • Handheld Device Integration: Core component for portable thermal imagers and industrial thermometers.
  • Fire Detection: Fixed-point monitoring for warehouses and forests with analog alert systems.
  • High-Definition Analog Core: The VOx detector offers a significant resolution boost (640x512) over standard analog thermal modules, ensuring crisp details.
  • Optimized for Motion: The 60Hz lossless output is specifically designed for scenarios involving fast movement, providing a blur-free experience.
  • Dual-Mode Temperature Measurement: Supports precise industrial-grade temperature analysis with stable readings across varying ambient conditions.
  • Compact & Durable Design: Measuring only 21x21x34.48mm, the black-finished module is easy to hide for discreet security or fit into tight internal housings.
  • Interchangeable Lens Ecosystem: While equipped with a 9mm lens by default, the module supports a range of lenses (13mm/25mm/35mm/50mm) to balance distance and field of view (FOV).
Detector type Uncooled Focal Plane Array Detector (VOx - Vanadium Oxide)
Frame rate 60Hz
Spectral Response 8~14μm
NETD 40mK@25℃, F#1.0, 25Hz
Resolution 640*512
Optical parameters
F.NO F1.0
Lens Focal Length 9mm
Detection Distance 900m
FOV(DxHxV) 46.2° x 37.7°
Recognition Distance 225m
Identification Distance 113m
Analog Video Interface CVBS(PAL Format)
Control Interface UART (Baud Rate: 115200)
Interface Specification SMD,P=0.8mm-4P
Application functions
Imaging Enhancement Mode Adjustable
Pseudo color White Hot (default), Black Hot
Brightness Adjustable
Contrast Adjustable
Digital Zoom 1X to 8X Zoom
Shutter Mode With Shutter, Auto Shutter Mode
Lib Calibration Support UART serial protocol
Non Uniformity Conrrection(NUC) Support UART serial protocol
Supply Voltage 5v~18v
Power Consumption ≤0.8w
Dimension 21mm x 21mm x 34.48mm
Weight 24.5g
Shock 80 g@4ms
Secondary Development /
Operating temperature -20℃ - +60℃
Certification RoHS,CE
  • 1 x Arducam 60Hz Thermal Imaging CVBS Camera Module
  • 1 x 5-pin Camera Connection Ribbon Cable
  • Signal Format: This module outputs an Analog CVBS signal. Please ensure your display or capture card supports analog video input (PAL/NTSC compatible).
  • Power Protection: Please check the voltage requirements before powering the module to prevent damage to the analog circuitry.
  • Lens Care: Do not expose the lens to high-intensity energy sources (like the sun) to prevent burning the infrared detector.
  • Customization: For specific focal lengths (e.g., 25mm or 50mm) or lensless versions, please contact our technical support for customization options.
