Arducam 5MP Camera Module for Renesas AI MPU RZ/V2L
Arducam 5MP MIPI Camera for AVNET MaaXBoard SBC Boards and RZBoard V2L with Renesas RZ/V2L Processor
Arducam 5MP OV5640 Camera Module for Renesas RZ/V2L Evaluation Kit
B0530
  • 5MP OV5640 sensor for clear, high-res imaging.
  • Designed for RZ/V2L Evk.
  • 84.2° DFoV fixed focus lens.
  • 30fps at 1080p for smooth video.
  • Compact 24x25mm board.
$24.99
Arducam 5MP camera, designed for the Renesas RZ/V2L Evaluation Kit, features an OV5640 sensor for high-res imaging with an 84.2° Dfov. It supports smooth 1080p video at 30fps and comes in a compact 24x25mm form factor, making it ideal for space-constrained applications needing high-quality visuals.
  • Surveillance camera
  • Logistics
  • Vision AI Gateway
  • Image inspection
  • IP camera
  • High-Resolution Imaging: Capture stunningly clear images and videos with the 5MP HD OV5640 sensor, delivering superior detail for your projects.
  • Designed for RZ/V2L: Specifically designed for RZ/V2L Evaluation Kit, ensuring optimal performance and ease of use.
  • Fixed Focus Lens: Benefit from an 84.2° Dfov that covers more area, making it perfect for applications that require a broader perspective.
  • Smooth Full HD Video: Enjoy smooth and crisp video recording at a maximum frame rate of 30fps at 1080p, ideal for high-quality video streaming and real-time monitoring.
  • Compact and Efficient: With a compact 24x25mm camera board, this module is perfect for space-constrained applications, providing powerful imaging capabilities without taking up valuable space.
Sensor OV5640
Still Resolution 2592x1944
Optical Size 1/4"
Output Format 8-/10-bit RGB RAW, RGB, YUV, JPEG
Pixel Size 1.4 µm x 1.4 µm
Sensor Active Area 2592(H) × 1944(V)
Video Modes 2592×1944@15fps, 1920×1080@30fps, 1280×720@30fps, 720x480@30fps, 640x480@60fps
FOV 84.2°(D)×71.7°(H)×57°(V)
Lens Mount Stock Lens
F.NO F2.0±5%
E.F.L 4.22mm
Distortion <1.0%
Operating Voltage 3.3V
Working Current Max: 300mA
Camera Board Size 24 × 25 mm
Supported Platform RZ/V2L
  • 1 x Arducam 5MP Camera Module
  • 1 x 15cm 24pin-15pin Camera Cable
  • Please note: Before using the camera, please follow the QUICK START guide below for configuration.
  • Introduction
  • Quick-Start-Guide
