Arducam 10MP USB Camera Evaluation Kit - CMOS MT9J001 1/2.3-Inch Monochrome Camera Module with USB2 Camera Shield
Arducam 5MP Fixed Focus USB2.0 Camera Evaluation Kit
EK042
  • Quick Evaluation: Ready-to-work camera & adapter bundle.
  • 5MP High Resolution: Based on 5MP image sensor. Active pixels: 2592(H)1944(V).
  • USB 2.0 Interface: Compatible with any hardware you choose.
  • Fixed Focus: Armed with a fixed focus Lens. Focus Distance: 60cm ~ INF.
  • SDK&API: Developer-friendly SDK& API for easy integration.
$99.99
To help customers evaluate the cameras or build a prototype with your own circuits without dealing with fine pin pitch flex cable or soldering balls, Arducam has released the evaluation kit with camera breakout boards and Arducam USB2/USB3 camera shield without writing a single line of code.
This camera evaluation kit is based on a 5MP resolution HD image sensor and equipped with a Fixed focus Lens. Meanwhile, accompanied by Arducam USB Camera Shield UI tools, it can achieve the adjustment of IR-cut, white balance, exposure, gain, and so on.
It comes with a 5MP camera module and our USB 2.0 camera adapter for you to build quick prototypes and proofs-of-concept with any backend hardware. The dev kit also comes with a complete SDK you can rely on to make easy integration into any machine vision applications. Arducam is committed to creating diverse and convenient camera solutions. For details, please refer to our official website www.arducam.com
  • Cellular phones
  • Toys and Tablets
  • Machine vision
  • ARM/FPGA/DSP based platforms
  • Product prototyping/development, etc.
  • 5MP high resolution: Capture clear and detailed images with 5 million pixels.
  • Precise fixed focus camera module: Ensures sharpness and clarity in your captured images.
  • Wide field of view (88°DFoV): Capture more in your frame for comprehensive imaging.
  • SDK&API Integrated: Fully Open-source and Developer-friendly SDK& API for easy integration.
  • Convenient bundle: Ready-to-use camera and adapter package for quick evaluation and setup.
Specs
Resolution/Frame Rate* JPG:
2592x1944@6fps, 1920x1080@6fps;
1600x1200@6fps, 1280x720@25fps;
640x480@30fps, 320x320@30fps;
320x240@30fps,128x128@30fps;
96x96@30fps
RGB and YUV:
320x240@30fps, 128x128@30fps;
96x96@30fps
Sensor Output Format JPG/YUV/RGB
Exposure Control Range -
Gain Control Range -
Focus Control Range -
Focal Length 2.46mm
Field of View(FOV) 88°(D)×75(H)×60°(V)
F.NO F2.0±5%
Power Consumption* 5V/0.38A
Operation Temperature 0-50 ℃
Evaluation Kit Size 40mmx40mm
Functions
Image File Format -
External Trigger Mode -
Software ISP -
Supported Programming Languages Python/C++
Supported OS Windows x86/x86_64
GUI(Graphical User Interface) Supported
Optional Items
Random Resolution These addtional functions require customized serivces to get supported. Please contact [email protected] for customization services.
Even Higher/Lower Frame Rate
More RAW Output Format Options(RAW10)
Long Exposure
  • 1 x Arducam 5MP USB2 Camera Evaluation Kit
  • 1 x USB2.0 Cable
  • You will need corresponding configuration files to use the camera kit on Arducam USB Camera Shield GUI, please contact [email protected] for the files.
