1.2MP Global Shutter USB Camera Evaluation Kit - CMOS AR0135 1/3-Inch Color Camera Module with USB2 Camera Shield-Arducam
Arducam 5MP ESP32 S3 Camera Module, Wi-Fi Bluetooth ESP32-S3 WROOM Development Board
EK043
  • Quick Evaluation: Ready-to-work camera & adapter bundle.
  • 5MP High Resolution: Based on 5MP image sensor. Active pixels: 2592(H)1944(V).
  • USB 2.0 Interface: Compatible with any hardware you choose.
  • Fixed Focus: Armed with a fixed focus Lens. Focus Distance: 60cm ~ INF.
  • SDK&API: Developer-friendly SDK& API for easy integration.
$49.99
ESP32 S3 Parameters:
Core:
Xtensa® dual-core 32-bit LX7 CPU,frequency up to 240MHz
Memories:
384 KB of ROM
512 KB of SRAM
16 KB of RTCSRAM
8 MB of PSRAM
Working Voltage: 3V to 3.6 V
Up to 45 GPIOs
2*12-bit ADC(up to 20 cahnnels)Communication interfaces:
2 I2C interfaces
2 I2S interfaces
4 SPl interfaces
3 UART interfaces
1 USB OTG interfaces
Security:
4096 bit OTP
AES、SHA、RSA、 ECC、RNG
Secure Boot, Flash Encryption, Digital Signature, HMAC module
Arudcam ESP32-S3 CAM camera module is a high-performance device featuring a 5MP camera with a 2592*1944 resolution and an integrated digital microphone. ts compact size makes it ideal for wearable devices, home smart devices, industrial wireless control, wireless surveillance, QR code identification, and other IoT applications.
  • Industrial Wireless Control
  • QR Wireless Identification
  • IoT Applications
  • Machine vision
  • ARM/FPGA/DSP-based platforms
  • High-Performance Camera Module: Features a 5MP camera sensor with a 2592*1944 resolution and an integrated digital microphone, ideal for high-quality image capture.
  • Powerful Processing and Storage: Equipped with an ESP32-S3 chip running up to 240 MHz, and includes 8MB PSRAM and FLASH, along with an SD card slot supporting up to 32GB of FAT memory for extensive storage needs.
  • Robust Wireless Connectivity: Supports dual wireless communication with 2.4GHz Wi-Fi and BLE.
  • Flexible Development Options: Compatible with Arduino and MicroPython, providing multiple development ports for versatile programming and application development.
  • Compact and Versatile Design: Its compact size makes it suitable for wearable devices and space-constrained projects such as home smart devices, industrial wireless control, wireless surveillance, QR code identification, and other IoT applications.
Specs
Resolution/Frame Rate 2592x1944@6fps,1920x1080@6fps, 1600x1200@6fps, 1280x720@25fps, 640x480@30fps,320x320@30fps, 320x240@30fps,128x128@30fps, 96x96@30fps
Sensor Output Format JPG/YUV/RGB
Focal Length 2.46 mm
Field of View(FOV) 88°(D)×75(H)×60°(V)
F.NO F2.0±5%
IR Sensitivity Intergal IR CUt filter
Power Consumption* Max: 5V/0.13A
Operation Temperature 0-50 ℃
Evaluation Kit Size 5.72×2.81 cm
  • 1 x Arducam ESP32 S3 Wroom 1 Camera Evaluation Kit
  • 1 x USB2.0 Cable (1m/3.3ft)
