Arducam 5MP AR0521 Color USB 3.0 Camera Module
Arducam 1.58MP IMX296 Color Global Shutter USB 3.0 Camera Module
Arducam 5MP AR0521 Monochrome USB 3.0 Camera Module
B0509
  • Arducam AR0521 boasts a 5MP monochrome sensor for crisp detail at 2592×1944 resolution.
  • Flexible frame rates up to 1080p@60fps adapt to any capture scenario.
  • M12 lens with 95°(D) FOV, low distortion, and NIR responsivity ensure clarity in varied environments.
  • On-board ISP with proprietary tech guarantees top-tier image enhancement.
  • Plug-and-play compatibility with Windows and Linux, no additional drivers needed.
Arducam's latest innovation in imaging technology, the AR0521 monochrome camera. Engineered as part of the Arducam USB 3.0 cameras series, this cutting-edge device boasts the prowess of the AR0521 sensor, a 5 MP powerhouse with a pixel size of 2.2 μm x 2.2 μm.
With an impressive Signal-to-Noise Ratio (SNR), this camera ensures minimal noise even in challenging conditions, while its near-infrared (NIR) responsiveness guarantees breathtaking image fidelity across diverse lighting scenarios. Thanks to the integration of a low-distortion lens, the AR0521 captures scenes with remarkable accuracy, offering users an authentic visual experience like never before.
  • Machine Vision
  • Video Surveillance
  • 3D Scanning and Metrology
  • Live Streaming
  • Video Conferencing
  • Crisp Clarity: With a high SNR 5MP monochrome AR0521 sensor, achieve a maximum still resolution of 2592x1944 for guaranteed clarity in every shot.
  • Flexible Capture: Enjoy flexible frame rates programmable up to 1080p@60fps. M12 lens with low distortion, fixed focus, and a 95°(D) field of view ensures monitoring clarity.
  • Enhanced Performance: Low noise and near-infrared (NIR) responsivity expand imaging possibilities, delivering exceptional performance even in challenging lighting conditions.
  • Proprietary on-board ISP: de-Bayer, gamma, BLC, AE, AWB, CCM, RGB2YUV.
  • Plug and Play: Seamless compatibility with Windows and Linux, plug-and-play functionality eliminates the need for additional drivers.
Sensor AR0521
Still Resolution 5 Megapixels
Color Filter Type Mono
Optical Size 1/2.5"
Pixel Size 2.2× 2.2 μm
Sensor Active Area 2592 × 1944
Frame Rate (USB 3.0) 2592x1944@30fps, 1920x1080@60fps
Frame Rate (USB 2.0) 1920x1080@10fps
Default Focus Range 1m-∞
FOV 95°(D) × 81°(H) × 65°(V)
Lens Mount M12 (S-mount)
E.F.L 3.6mm
Power Requirements Max: 1.6W  , Min: 0.9W
  • 1 x AR0521 Mono USB3.0 Camera with Back Cover and Tripod Mount
