Arducam IMX283 USB 3.0 camera equipped with a 1-inch IMX283 CMOS. It achieves astonishing image clarity at a max resolution of 5472x3648. This camera offers programmable frame rates, providing the flexibility to reach up to 120fps at 720p resolution for dynamic video capture.
The camera features an onboard ISP and center-weighted exposure. This intelligent combination ensures uncompromised output in uncompressed YUY2 format. The camera's 16mm C-mount lens, boasting a 60° FOV, guarantees telephoto excellence, capturing scenes with precision and detail.
| Image Sensor | |
| Sensor | IMX283 |
| Still Resolution | 20 Megapixels |
| Color Filter Type | Color |
| Shutter Type | Rolling |
| Optical Size | 1" |
| Output Format | YUY2 |
| Pixel Size | 2.4 µm x 2.4 µm |
| Sensor Active Area | 5496(H)×3672(V) |
| Frame Rate (USB 3.0) | 1280×720@120fps, 1920×1080@60fps, 2720×1536@40fps, 3840×2160@20fps, 5472×3648@9fps |
| Frame Rate (USB 2.0) | 1280×720@10fps |
| Lens | |
| Focus Type | Manual Focus |
| FOV | 60°(D)×49°(H)×38°(V) |
| Lens Mount | C-Mount |
| F.NO | F1.4-16 |
| E.F.L | 16mm |
| *Default Focus Range | 5m-∞ |
| USB Interface | |
| Power Requirements | Max: 1.38W , Min: 0.75W |
| UVC Controls | Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Manual/Auto) |
