Arducam 5MP IMX335 OIS USB 3.0 Camera Module
Arducam 20MP IMX283 USB 3.0 Camera Module with 16mm C-Mount Lens
Arducam 13MP IMX258 OIS Motorized Focus USB 3.0 Camera Module
B0485
  • Plug and play
  • Based on 13MP IMX258, maximum still resolution of 4208×3120
  • Optical Image Stabilization USB Camera
  • Programmable frame rates, reach up to 60fps@720p
was $249.99 Special Price $199.99
Embark on a new level of imaging precision with Arducam's latest addition to the USB 3.0 camera series—the IMX258 stabilized camera. Engineered for excellence, it boasts Optical Image Stabilization (OIS) to deliver sharp, clear images, even in dynamic sports scenes.
This advanced camera is built on a 1/3.06" IMX258 CMOS sensor, providing a maximum still resolution of 4208x3120. The expansive 123° (D) wide-angle field of view ensures comprehensive scene capture, perfect for diverse photography needs.
  • Machine Vision
  • Video Surveillance
  • 3D Scanning and Metrology
  • Live Streaming
  • Video Conferencing
  • Superior Imaging: Utilizing a 1/3.06" IMX258 CMOS sensor, achieve sharpness at max still resolution 4208x3120.
  • Flexible Frame Rates: Programmable your desired frame rates, even reaching 60fps at 720p.
  • Proprietary on-board ISP advances image enhancement: de-Bayer, gamma, BLC, AE, AWB, CCM, RGB2YUV.
  • Optical Image Stabilization: Capture sharp and stable shots with OIS and experience an expansive 123° (D) field of view for immersive photos and videos.
  • Plug and Play: Encased in an all-inclusive metal housing, its compact design makes it plug-and-play ready for on-the-go creativity.
Sensor IMX258
Still Resolution 13 Megapixels
Optical Size 1/3.06"
Pixel Size 1.12 µm x 1.12 µm
Sensor Active Area 4224(H)×3192(V)
Frame Rate (USB 3.0) 1280*720@60fps,1920*1080@40fps,2096*1560@30fps,3840*2160@20fps,4208*3120@12fps
Frame Rate (USB 2.0) 1280*720@10fps
Stabilizer Type Optical Image Stabilization (OIS)
Stabilizer Dimensions 19.0*19.0*9.9 mm
Stabilizer Compensation Axis No. 2 (Pitch and Yaw)
Stabilizer Compensation Angle ≤±4°
Stabilizer Compensation Ratio ≥21 dB
Stabilizer Resonant Frequency TBD
Stabilizer Average Power 180 mW
Focus Type Motorized Focus
FOV 123°(D)×112°(H)×96°(V)
Lens Mount M6.5
F.NO F2.4
E.F.L 2.35mm
Default Focus Range 10cm-∞
Power Requirements Max: 1.5W  , Min: 0.81W
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Manual), Exposure (Manual/Auto)
  • 1 x IMX258 USB3.0 Camera Module with Enclosure
