Arducam 12MP IMX708 Quad-Camera Kit, Wide Angle Stereo Synchronized Camera Module for Raspberry Pi
Arducam 2.3MP*2 AR0234 Color Global Shutter Synchronized Stereo Camera Bundle Kit for Raspberry Pi
B0492R
  • Based on color global shutter CMOS AR0234
  • Compatible with Raspberry Pi 5/4B
  • Complete Synchronized: up to 2 cameras capturing at the same time.
  • Color Global Shutter: Excellent detail and sensitivity for real-time, higher accuracy and frame rates
  • Better Control: single/dual channel modes.
$259.99
This Arducam stereo camera bundle kit consists of two synched AR0234 global shutter cameras and an Arducam Camarray stereo camera HAT.
As a stereo bundle system, it enables simultaneously working dual cameras with a variable baseline for better prototyping and evaluation with a single MIPI CSI camera slot: The two image sensors are on separate camera boards, and you easily move them around for different perspectives while the Camarray HAT handles the rest of the work.
  • Head, and eye tracking
  • Gesture detection
  • Motion detection
  • 3D reconstruction
  • Depth-related vision applications
  • Precision Sync: Based on AR0234, a color global shutter CMOS,  ensuring flawless synchronization.
  • Rapid Capture: Leveraging the low-latency capabilities of the global shutter, it achieves a swift 94fps frame rate for seamless imaging.
  • Trigger Flexibility: This camera supports an external trigger function, enhancing control and adaptability to diverse scenarios.
  • Crisp Clear Vision: Fitted with an M12 low distortion lens, ensuring sharp and undistorted images for accurate analysis.
  • Supported by Raspberry Pi, only install arducam-pivariety driver for hassle-free integration.
Image Sensor AR0234
Shutter Type Global Shutter
Optical Size 1/2.6"
Pixel Size 3 µm x 3 µm
Output Format RAW10
Video Modes
(on Raspberry Pi)
2560×720@94fps, 3840×1080@38fps, 3840×1200@38fps
Focus Type Manual
Focal Length 3.6mm
Field of View (FOV) 120°(D)×90°(H)×75°(V)
Lens Mount M12-mount
Distortion <-0.33%
Default Focus Range 2m-infinite
Working Current Max 380 mA
Camera Board Size 40 ×40 mm
Camarray Hat Size 65×56 mm
Supported OS Raspberry Pi OS
Supported Platforms Raspberry Pi
ISP Support Supported by Raspberry Pi
External Trigger Support
Aggregate mode Full Spelling Combine
  • 2 x Arducam AR0234 Camera Module
  • 1 x UC-512 Camarray HAT
  • 2 x 15cm 22-22pin FFC Camera Cable
  • 1 x 30cm 22-22pin FFC Cable
  • 1 x 73mm 15-22pin Camera Cable
  • 1 x Screw Pack
  • The kit does not include the Raspberry Pi Board.
  • The AR0234 cameras included in the kit are exclusively designed and can only be utilized with the Camarray HAT. Directly connecting any of them to the Raspberry Pi will not function.
  • This bundle kit is not recommended for Raspberry Pi Zero.
  • The I2C signal and clock of each camera are fully synchronized. It is unavailable to capture the same frame of images at different exposure times for each camera.
  • The lens on this camera is not interchangeable, if you need to replace the lens, please contact sales in advance!
  • The kit only supports the latest Raspberry Pi OS and libcamera apps. Legacy OS users should contact sales for support.
    Raspberry Pi 5
    Raspberry Pi 4B / 3B+ / 3A+
