Arducam 2.3MP AR0234 Color Global Shutter USB 3.0 Camera Module-With Enclosure
Arducam 2MP Sony STARVIS IMX462 Ultra Low Light Manual Focus USB 3.0 Camera Module-With Enclosure
Arducam 2.3MP AR0234 Color Global Shutter USB 3.0 Camera Module-Without Enclosure
B0495-1
  • Plug and play
  • Based on 2.3MP AR0234, maximum still resolution of 1920*1200
  • Color Global Shutter with Programmable frame rates, reach up to 80fps@960×600
  • M12 manual focus lens for Precision focus and wide 95°(D) view.
$139.99
Arducam's USB 3.0 camera series presents the AR0234 color global shutter model. Featuring a 1/2.6" 2.3MP CMOS, it attains a max still resolution of 1920x1200. Now supporting YUYV format output for uncompressed, high-quality images. The global shutter and rapid 80 fps frame rate ensure silky smooth HD video.
The camera boasts an M12 low-distortion lens with a 95° diagonal field of view, delivering more accurate, distortion-free images.
  • Machine Vision
  • Video Surveillance
  • 3D Scanning and Metrology
  • Live Streaming
  • Video Conferencing
  • Outstanding Imaging: Utilizes a 2.3MP Global Shutter AR0234 sensor for sharpness, achieving a max still resolution of 1920x1200.
  • Fast and Precise: Flexible Frame Rates, programmable up to 960x600@80fps. M12 lens with low distortion, manual focus, and a 95°(D) field of view for monitoring clarity.
  • Color Global Shutter: Capture crisp images of high-speed motion, free from rolling artifacts.
  • Advanced Image Enhancement: On-board ISP with proprietary tech ensures top-tier image quality through de-Bayer, gamma, BLC, AE, AWB, CCM, and RGB2YUV processes.
  • Plug and Play: Seamless compatibility with Windows and Linux, plug-and-play functionality eliminates the need for additional drivers.
Sensor AR0234
Shutter Type Global Shutter
Optical Size 1/2.6"
Pixel Size 3 µm x 3 µm
Frame Rate (USB 3.0) 1920*1200@50fps, 960*600@80fps
Frame Rate (USB 2.0) 960*600@10fps
FOV 98°(D)×85°(H)×69°(V)
Lens Mount M12
F.NO F2.5
E.F.L 3.56mm
Default Focus Range 2m-∞
Power Requirements Max: 1.45W  , Min: 0.92W
  • 1 x AR0234 USB3 Camera with Back Cover and Tripod Adapter
