Arducam 5MP Fixed Focus USB 3.0 Camera Evaluation Kit
Arducam 2.2MP Mira220 MONO Global Shutter USB3.0 Camera Evaluation Kit
Arducam 2.2MP Mira220 RGB Global Shutter USB3.0 Camera Evaluation Kit
EK037
  • Based on mira220, 1/2.7” 2.2MP Enhanced Global Shutter Image Sensor.
  • High Frame Rate 80fps, Low Distortion M12 lens, High NIR sensitivity.
  • USB 3.0 interface: Compatible with any hardware you choose.
  • Developer-friendly SDK: & API for easy integration.
$299.99
To help customers evaluate the cameras or build a prototype with their own circuits without dealing with fine pin pitch flex cable or soldering balls, Arducam released the evaluation kit with camera breakout boards and Arducam USB2/USB3 camera shield without writing a single line of code.
The camera evaluation kit is based on the Mira220, an enhanced 1/2.7" 2.2MP global shutter image sensor. Its rapid evaluation setup includes an immediately available camera and adapter kit, which, together with the Arducam USB Camera Shield UI tool, ensures a seamless integration experience for developers.
Capable of high frame rates up to 80fps, the Mira220 specializes in capturing fast-paced scenes with exceptional clarity. The USB 3.0 interface ensures compatibility with a wide range of hardware, providing flexibility for a variety of applications. The addition of a low-distortion M12 lens enhances its adaptability to different imaging scenarios. Developers will appreciate the kit's user-friendliness, featuring developer-friendly SDKs and APIs for easy integration into existing projects. In addition, the Mira220 features high NIR sensitivity, making it ideal for applications that require enhanced performance in low-light conditions.
  • Mobile Facial Authentication
  • Smart Home Appliances
  • Enhanced Global Shutter CMOS: Built on Mira220's 2.2 MP sensor, excels in 2D/3D machine vision with global shutter and BSI technology, delivering superior image quality.
  • Speedy Capture: Mira220 achieves a maximum frame rate of 80 fps, enabling real-time imaging for dynamic applications.
  • Low-Distortion M12 Lens: Enhanced with a high-res M12 lens, ensuring crisper images.
  • High NIR Sensitivity: Classing leading QE at 940 nm, ideal for challenging lighting conditions.
  • Effortless Integration: The camera & adapter bundle, paired with a USB 3.0 interface, offers quick evaluation, seamless integration, and user-friendly adjustments for diverse applications.
Sensor Features
Sensor Mira220
Still Resolution 2.2MP
Color Filter Type RGB
Shutter Type Global Shutter
Optical Size 1/2.7"
Sensor Output Format RAW12 (RGB)
Pixel Size 2.79μmx 2.79μm
Sensor Active Area 1600(H)×1400(V)
Frame Rate 1600x1400@30fps, 640x480@80fps
Exposure Control Range 12us-33333us
Gain Control Range Not Support
FOV 80°(D)*68°(H)*53°(V)
E.F.L 3.6mm
Operating Temp. 0°C to 50°C
Power Requirements Max: 1.32W
Evaluation Kit Size 38mmx38mm
Image File Format DNG/JPEG
Software ISP Not Supported
Supported Programming Languages Python/C++
Supported OS Windows x86/x86_64
GUI(Graphical User Interface) Supported
Optional Items
Random Resolution These additional functions require customized services to get supported. Please contact [email protected] for customization services.
Even Higher/Lower Frame Rate
More RAW Output Format Options(RAW10)
Long Exposure
External Trigger Mode
  • 1 x Mira220 RGB USB3 Camera Evaluation Kit with Back Cover and Tripod Adapter
  • 1 x 1M USB Cable
  • You will need corresponding configuration files to use the camera kit with Arducam USB Camera Shield GUI, please get in touch with [email protected] for the files.
