The Arducam UVC3.0 Global Shutter Series Mira220 USB 3.0 camera features a 1/2.7" 2.2MP NIR-enhanced global shutter sensor, delivering Class-leading QE at 940nm. Designed for low-light environments, this camera provides exceptional clarity for high-demand imaging applications.
With support for frame rates up to 80fps, the Mira220’s low-distortion M12 lens captures sharp, distortion-free images, even in fast-moving scenes. Advanced ISP technology enhances image quality through debayering, gamma correction, and color correction, ensuring accuracy and vibrant detail.
Enjoy easy plug-and-play functionality on Windows and Linux with USB 3.0 compatibility—no drivers required. Backward compatible with USB 2.0, the Mira220 provides versatile and reliable performance, making it ideal for high-speed imaging needs and professional results.
| Image Sensor | |
| Sensor | Mira 220 |
| Still Resolution | 2.2MP |
| Color Filter Type | Mono |
| Shutter Type | Global Shutter |
| Optical Size | 1/2.7" |
| Output Format | YUY2 |
| Pixel Size | 2.79μmx 2.79μm |
| Sensor Active Area | 1600(H)×1400(V) |
| Frame Rate (USB 3.0) | 1600*1400@30fps, 640*480@80fps |
| Frame Rate (USB 2.0) | 640*480@10fps | Lens |
| Focus Type | Manual Focus |
| FOV | 80°(D)×68°(H)×53°(V) |
| Lens Mount | M12 (S-mount) |
| F.NO | F2.8 |
| E.F.L | 3.6mm |
| IR Sensitivity | No IR-cut filter, sensitive to IR |
| Default Focus Range | 1m-∞ |
| USB Interface | |
| Power Requirements | Max: 1.4W |
| UVC Controls | Brightness, Contrast, Exposure (Manual/Auto) |
