Arducam 12MP IMX477P USB 3.0 Camera with M12 Manual Focus Lens-Without Enclosure
Arducam 2.2MP Mira220 MONO Global Shutter USB 3.0 Camera-Without Enclosure
Arducam 2.2MP Mira220 MONO Global Shutter USB 3.0 Camera-With Enclosure
B0536C
  • 1/2.7″ 2.2MP mono NIR-enhanced global shutter image sensor (Mira220)
  • Up to 80fps with low-distortion M12 lens and high NIR sensitivity
  • Leading QE performance at 940nm
  • Enhanced image quality with advanced on-board ISP
  • USB 3.0, UVC compliant, plug-and-play, no drivers needed
$164.99
The Arducam UVC3.0 Global Shutter Series Mira220 USB 3.0 camera features a 1/2.7" 2.2MP NIR-enhanced global shutter sensor, delivering Class-leading QE at 940nm. Designed for low-light environments, this camera provides exceptional clarity for high-demand imaging applications.
With support for frame rates up to 80fps, the Mira220’s low-distortion M12 lens captures sharp, distortion-free images, even in fast-moving scenes. Advanced ISP technology enhances image quality through debayering, gamma correction, and color correction, ensuring accuracy and vibrant detail.
Enjoy easy plug-and-play functionality on Windows and Linux with USB 3.0 compatibility—no drivers required. Backward compatible with USB 2.0, the Mira220 provides versatile and reliable performance, making it ideal for high-speed imaging needs and professional results.
  • Mobile Facial Authentication
  • Smart Home Appliances
  • Enhanced Global Shutter CMOS: The 2.2MP Mira220 mono image sensor, combines global shutter and BSI technology for outstanding image quality.
  • Fast Capture: Supports up to 80fps for real-time imaging in dynamic applications.
  • Low Distortion M12 Lens: High-resolution M12 lens delivers sharper, clearer images.
  • High NIR Sensitivity: Industry-leading QE at 940nm, ideal for low-light conditions.
  • Advanced On-Board ISP: Enhances image quality with de-Bayer, gamma correction, AE, and RGB2YUV conversion.
Sensor Mira 220
Still Resolution 2.2MP
Color Filter Type Mono
Shutter Type Global Shutter
Optical Size 1/2.7"
Pixel Size 2.79μmx 2.79μm
Sensor Active Area 1600(H)×1400(V)
Frame Rate (USB 3.0) 1600*1400@30fps, 640*480@80fps
Frame Rate (USB 2.0) 640*480@10fps
FOV 80°(D)×68°(H)×53°(V)
Lens Mount M12 (S-mount)
E.F.L 3.6mm
Default Focus Range 1m-∞
Power Requirements Max: 1.4W
UVC Controls Brightness, Contrast, Exposure (Manual/Auto)
  • 1 x Mira220 MONO USB3 Camera with Back Cover and Tripod Adapter
  • 1 x USB A to Type-C Cable (1m)
