[Discontinued] Arducam 1MP OV9282 Mono global shutter drop-in replacement for DepthAI OAK-D(NoIR)
Arducam 1MP OV9782 Global shutter color MIPI camera module 20pin for DepthAI OAK-FFC-3P-OG
[Discontinued] Arducam 1MP OV9282 Global shutter Mono MIPI camera module 20pin for DepthAI OAK-FFC-3P-OG
B0297
Discontinued, check alternative item B0334.
$44.99
The Arducam 1MP OV9282 Global shutter Mono MIPI camera module is designed for DepthAI OAK,
Supported DeptAI version: OAK-FFC-3P-OG (BW1098FFC R0M0E0)
  • Sensor: Mono global shutter OV9282
  • Pixel Size: 3 μm x 3 μm
  • Active array size: 1280 x 800
  • Optical Size: 1/4 inch
  • Focusing Range: 20cm ~ infinite
  • IR Sensitive: Without IR filter
  • Output interface: MIPI 2-Lane
  • Output formats: RAW8/RAW10
  • Maximum image transfer rate: 1280 x 800@120 fps
  • Board Size: 24mm x 25mm
  • Lens: Low distortion M12 lens (Part Number: M27280M07S)
  • EFL: 2.8mm
  • F.N: 2.8
  • HFOV: 75 Deg
3D drawing.step
  • 1 pcs Arducam 1MP OV9282 Global shutter Mono MIPI camera module 20pin for DepthAI OAK
  • 1 pcs 150mm 20pin-20pin FPC cable(same side)
