Arducam 5MP Auto Focus Mini USB Camera Board for Computer, 1/4” CMOS OV5648 UVC USB2.0 Video Webcam with Microphone
Arducam 100fps Global Shutter Color USB Camera Board, 1MP OV9782 UVC Webcam Module with Low Distortion M12 Lens Without Microphones
16MP A298 Autofocus USB2 UVC Camera Module with Metal Case, Multiple preset AI resolutions
B029001
  • [Autofocus] Armed with 60°(H) excellent Autofucs Lens.
  • [Compatible with All Platforms]: Compatible with Windows, Linux, Mac, and so on.
  • [High Quality Imaging] 16MP for sharp image with still picture resolution at 4656 x 3496 Max.
  • [Alternative Options]: Select Upgraded Version(B029002C) for more preset AI resolution(YUV).
$51.99
Arducam 16MP A298: 16MP USB camera module designed for high-quality imaging up to 4656 x 3496 resolution. With plug-and-play compatibility on Windows, Linux, Android, and macOS—no driver required—the A298 is a reliable UVC solution for applications demanding clarity, durability, and wide dynamic range.
Check upgraded version(B029002C) with more preset AI resolution for rapidly training and development of AI models, while the sturdy metal housing provides effective heat dissipation and protection.
[Plug-and-Play]
This 16MP camera module offers hassle-free plug-and-play operation across Windows, Linux, Android, and macOS platforms. No additional drivers or software are required—simply connect via USB and start capturing high-quality images instantly.
[AI Resolution]
Multiple preset AI image resolution. You can directly train and deploy your AI model without additional image cropping.
[Autofocus]
Featuring excellent autofocus lens, the camera automatically adjusts focus to maintain sharp and clear images across various distances, making it suitable for dynamic scenes and versatile applications.
[Upgraded Option]
Check B029002C, which is equipped with more preset AI resolution. Same price, better performance.
Specification
General Sepcs B029002C(Upgraded) B029001-1(Standard)
Still Resolution 16MP 16MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/2.8'' 1/2.8"
Sensor Active Area 4656(H) x 3496(V) 4656(H) x 3496(V)
Frame Rate(MJPG) 4656x3496@10fps, 4000x3000@15fps;
3840x2160@25fps, 3264x2448@25fps;
2592x1944@30fps, 1920x1080@30fps;
1280x720@30fps, 640x480@30fps;
4656x3496@10fps, 3840x2160@10fps;
, 2592x1944@10fps, 1920x1080@30fps;
1280x720@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
640×480@20fps, 320x240@30fps;
FOV 75°(D)×61°(H)×50°(V) 60°(H)
F.NO F1.8 /
E.F.L 3.95mm /
Operating Voltage 5V 5V
Power Consumption 1.75W 1W
HDR Support NO NO
Enclosure with Metal Enclosure with Metal Enclosure
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
Manual.pdf
Manual.pdf
