Arducam PTZ camera is a complete solution to turn your Raspberry Pi/Jetson Board, and it is capable of remote directional and zoom control, so it could move the camera and the lens, and that means a single camera can be used to monitor places that should be covered by multiple ones.
You can save a lot of cost and time in purchasing and deploying the camera. What’s more, this kit is based on the IR-CUT switchable 12MP Sony IMX477 camera to get sharp images all day and night.
The 22-22pin FFC Cable is included in the package. But please note that: If you are using an AGX Orin, an additional camera adapter (B0473) is also required.
| Sensor | Sony IMX477 |
| Optical Format | Type 1/2.3(Diagonal 4.60mm) |
| Resolution | 12.3MP |
| Pixel Size | 1.55 µm x 1.55 µm |
| Active Pixels | 4056(H) x 3040(V) |
| Frame Rates | Raspberry Pi: 2028 × 1080p50, 2028 × 1520p40 and 1332 × 990p120 NVIDIA Jetson Orin NX/Orin Nano/AGX Orin: L4t 32.x: 4032x3040@30fps, 3840x2160@30fps, 1920x1080@60fps L4t 35.x: 4032x3040@20fps, 3840x2160@30fps, 1920x1080@60fps |
| Shutter Type | Rolling Shutter |
| Focus Type | Front group: focus Back group: Zoom |
| Focal Length | 4.38-10.71mm±5% |
| FOV | 96° – 33° (Horizontal) |
| IR Sensitivity | Optional with additional Motorized IR-Cut filter |
| Camera Board Size | 36mm x 36mm |
| Pan and Tilt Range | 0-180° |
| Zoom Range (Wide => Tele) | 2317 steps 0.00396mm/step |
| Focus Range(Near => Far) | 3009 steps 0.0047mm/step |
1. 5MP OV5647 / 8MP IMX219 Camera No. Items Specification 1 F No. W:1.6-T:3.3±5% 2 Focal-Length 3.2-11.1mm±5% 3 Optical Back Focal Length 5.8±0.1 4 Mechanical Back Focal Length 13.45±0.2 5 TTL 52.14±0.2 6 Image Circle ∅6.9 7 Lens Structure 6G3P 8 Mount ∅14 9 FOV 1/2.7”(16:9): H(113~30),V(60~16),D(137~34) 1/3”(4:3): H(91~25),V(66~18),D(120~30) 1/4”(4:3): H(67~18),V(49~13),D(90~22) 10 M.O.D 0.8m 11 […]
Hardware Setup Please note that in this illustrator, the different colors of the jumper wires are just to make it easier to distinguish them from each other. The order of those colors varies from item to item, so it may not match the one you’ve received. Therefore, instead of its color, you should rely on […]
0. Introduction The Arducam IMX477 12MP PTZ camera mainly consists of the following two systems: An Arducam IMX477 12MP Camera Module A driver-board-based PTZ controlling system for Pan-tilt servos and Lens motors (Zoom and Autofocus) It comes in two models with different package items. The following table shows their differences. Camera w/ Zoom Lens PTZ […]
Used on Raspberry Pi:
Used on Jetson Board:
