The Arducam 1080P Day & Night Vision MIPI Camera Module is an elite imaging solution purpose-built for Raspberry Pi enthusiasts and industrial integrators. Powered by premium Sony STARVIS™ starlight technology, it achieves unparalleled sensitivity, delivering sharp and clear video under extremely dim conditions. Designed as a native Raspberry Pi camera solution, it requires no complicated firmware flashing and can be called directly by the platform out of the box. Featuring a 102° wide-angle lens and automatic day/night switching, this compact module is the ultimate choice for round-the-clock monitoring and embedded vision projects.
Smart Home Security: Provides reliable, 24/7 continuous surveillance for indoor and outdoor home monitoring systems.
Wildlife Research & Tracking: Perfect for capturing nocturnal animal activities without disrupting their natural environment with bright lights.
IoT Environmental Monitoring: Enables remote stations to capture high-quality visual data in changing outdoor lighting conditions.
Robotics and Drones: Ideal for autonomous robots navigating through dimly lit warehouses or outdoor night environments.
[Sony STARVIS™ Technology] Leveraging Sony's premier starlight-level back-illuminated pixel technology, this camera module drastically increases light sensitivity, ensuring bright and highly detailed images even in near-total darkness.
[True Day & Night Adaptation] Seamlessly transitions between vibrant color imaging during the day and crisp, high-contrast monochrome vision at night, providing a perfect 24/7 surveillance solution.
[Native Raspberry Pi Integration] Fully compatible with Raspberry Pi’s official camera drivers and software stacks, allowing users to call the camera directly via command lines without flashing custom firmware.
[Expansive 102° Field of View] Equipped with a high-quality 102-degree diagonal wide-angle lens that maximizes scene coverage, effectively reducing blind spots in critical security and monitoring setups.
[High-Definition 1080P Streaming] Delivers smooth, uncompressed 1080P Full HD video through the high-speed MIPI CSI-2 interface, ensuring pixel-perfect accuracy for video streaming, recording, or AI vision analysis.
SONY STARVIS IMX290
2 Megapixels
Chroma
Color
Rolling Shutter
Optical Format
1/2.8"
Pixel Size
2.9 µm x2.9 µm
Sensor Active Area
1920(H)×1080(V)
Sensor Image Area
5.640 mm x 3.181 mm (6.46 mm diagonal)
Output Format
RAW10/RAW12
Resolution@fps
1920x1080@60fps, 1280x720@60fps;
Focus Type
Fixed Focus
FOV
102°(D)×86°(H)×46°(V)
Lens Mount
M12*P0.5
F.NO
F1.6±10%
E.F.L
3.98±5%mm
IR Sensitivity
Day&Night Vision, IR-Cut Switch (IR650/NoIR)
Default Focus Distance
168cm-INF
Distortion
TV Distortion: -11.3%
F-θ Distortion: -34.9%
TTL
22.7±0.2 (in air)
M.O.D
2m
IR-Cut Switch
Onboard Manual Switch
IR LED Light
No
Supported Platform
Raspberry Pi
Supported Raspberry Pi OS
Bullseye/Bookworm/Trixie
Camera Interface
MIPI CSI-2
Operating Voltage
3.3V
Power Consumption
0.9W
Camera Board Size
32×32 mm
Overall Weight (Net)
16g
Temperature range (Storage)
-4°F-167°F (-20°C to +85°C)
Temperature range (Operating)
32°F-122°F (0°C to +50°C)
Certification
RoHS
1 x Arducam 2MP Ultra Low Light IR-Cut Switch MIPI Camera Module
