This camera is based on 8MP IMX219 USB Camera Module. The max resolution&frame rate of this camera is 3280(H)×2464(V)@30fps. Besides, we have equipped the camera with Auto Focus Lens. Arducam team is committed to creating more convenient and more efficient camera solutions. We have expanded the using scope of the image sensor, enabling the camera to realize your various projects. The camera is equiped with a 62°(H) autofocus lens, allowing you to use it for more applications. It is compatible with Windows, Linux, Android and MAC and no additional drivers is required. If you have any other requirements, please communicate with our sales team, we look forward to further cooperation with you.
3D Scanner
VR Camera
Lightburn Laser Engraver Machine
Surveillance
Video System
Full HD Autofocus: 8MP (3280 x 2464)@30fps, full HD USB camera with autofocus lens; Capture most exciting details at every 30/15fps, FoV: 62°(H)
High Resolution: Picture format MJPEG or YUY2 optional, cameras with high resolution can be used in any video system for industrial.
UVC Compliant: OTG supported just plug the USB cable into your PC’s USB port, and running the software can capture the high-level video and continuous recording, no driver needed.
Wide Compatibility: USB cameras are widely available for Windows, Android, Linux, and Mac OS with UVC protocol.
Flexible Application: Lightweight and compact size is perfect for embedded applications, and ideal for Video systems, 3D scanners, VR cameras, electronic microscopes, and medical machines.
