8MP IMX219  3280(H)×2464(V)@30fps USB Camera Module with Sigle Microphone for Linux, Windows, and Mac OS
8MP A219 Autofocus USB2 UVC Camera Module with Metal Case, HDR-enabled Module Available
IMX179 8MP Autofocus USB Camera Module, 1/3.2" 3264(H)×2448(V)@30fps with Sigle Microphone for Linux, Windows, and Mac OS
UB0240
  • Frame Rate: 4K(3264×2448)@30fps, full HD USB camera with autofocus lens; Capture most exciting details at every 30/15fps, FoV: 65°(H)
  • MJPEG/YUYV: Picture format MJPEG or YUY2 optional, cameras with high resolution can be used in any video system for industrial.
  • UVC Compliant: OTG supported just plug the USB cable into your PC’s USB port, and running the software can capture the high-level video and continuous recording, no driver needed.
  • Support OS: USB cameras are widely available for Windows, Android, Linux, and Mac OS with UVC protocol.
  • Mini Sized: Lightweight and compact size is perfect for embedded applications, and ideal for Video systems, 3D scanners, VR cameras, electronic microscopes, and medical machines.
$45.99
This camera is based on 8MP IMX179 USB Camera Module. The max resolution&frame rate is 3264(H)×2448(V)@30fps. Besides, we have equiped the camera with Auto Focus Lens. Arducam has developed and designed this camera based on SONY IMX179 sensor. Arducam team is committed to creating more convenient and more efficient camera solutions. We have expanded the using scope of the sensor, enabling the camera to realize your various projects. The camera is equiped with a 65°(H) autofocus lens, allowing you to use it for more applications. It is compatible with Windows, Linux, Android and MAC and no additional drivers required. If you have any other requirements, please communicate with our sales team, we look forward to further cooperation with you.
  • 3D Scanner
  • VR Camera
  • Lightburn Laser Engraver Machine
  • Surveillance
  • Video System
Image Sensor Sony IMX179
Resolution 8MP
Color Filter Color
Optical Format 1/3.2"
Output Format YUYV/MJPG
Pixel Size 1.4μm*1.4μm
Active Pixels 3264(H)×2448(V)
Frame Rate MJPG: 30fps@Full Resolution
YUY2: 1fps@3264 x 2448; 2fps@2592 x 1944/2048 x 1536; 5fps@1920 x 1080/1600 x 1200; 7.5fps@1280 x 960; 10fps@1280 x 720; 15fps@1024 x768; 25fps@800 x 600; 30fps@640 x 480
Focus Type Autofocus
FOV 65°(H)
Lens Mount M6.5*P0.25mm
F.NO 2.0±5%
Focal Length 3.543mm±5%
Distortion <1%
Interface USB 2.0 device
Connector SM05B-SRSS-TB
UVC Compliant no additional drivers required
Operating Voltage DC 5V +/- 5%
Work Current Max 300mA
Operating Temp. -4℉-158℉(-20°C to 70°C)
Camera Board Size 62mm x 9mm x 6mm
Audio Single Microphone
Supported OS Windows, Linux, Android and MAC
Sample Application Amcap-Windows Camera application
for Video and Still Capture
UVC Controls Brightness, Contrast, Hue, Saturation, Sharpness, Gamma, White Balance, Gain, Exposure
  • 1 x Arducam IMX179 8MP Camera Module
  • 1 x USB Cable (1m)
  • No platform board (Raspberry Pi/Nvidia Jetson Nano/NX board) is included in the package
Documentations
