By bringing a sensor inside modern-day flagship phones to Raspberry Pi. you can take DSLR-like still images at the maximum resolution of 9152 x 6944. And with an autofocus lens, the ePTZ, and the upcoming continuous-autofocus features.
You now get more horsepower to build more applications, to cover more industries, to unlock more fields, at a much lower cost.
For seasoned makers, Pi Hawk-eye is designed to ensure you a smooth upgrade, it is compatible with everything you already have: the v1/v2 form-factor, the MIPI CSl-2 connection, the latest libcamera software, the standard tripod mount. etc.
Even if you are using Raspberry Pi for the first time, you can follow the hands-on guide without hassle.
*Only kernel version 6.1.21 and later support 48MP and PDAF
**Raspberry Pi 2/3/Zero W may not be able to enable 9152×6944 and 8000×6000 due to RAM, please make sure your platform has more than or equal to 1G of RAM.
Packing Including
1 x 64MP-AF Camera Board
1 x 15cm 22-22pin FPC Cable
1 x 15cm 15-22pin FPC Cable
