64MP Autofocus Synchronized Quad-Camera Kit for Raspberry Pi
Ribbon Cable Set (1.5″, 2.87″, 5.9″) for Raspberry Pi 0 and Zero 2W, Pack of 3
64MP PDAF&CDAF Autofocus Camera for Raspberry Pi
B0399
    Explore Arducam's latest Pivistation 5, All-in-one Pi5 Camera. See the story on Kickstarter.
  • 64 Megapixels: first camera module for RPi offering specs matching smartphones.
  • Autofocus: most versatile AF (Manual/Continuous/etc.) experience on a Pi camera.
  • 10x Digital Zoom: ePTZ support for super close-up views and captures.
  • libcamera-ready: native software compatibility with a v1/v2-like form factor.
  • Smooth Upgrade: works on most Pis with a CSI-2 connection.
arducam shipping payment 1
$59.99
A 64-megapixel ultra high-resolution autofocus camera module exclusively built for the latest and future generations of Raspberry Pis.
By bringing a sensor inside modern-day flagship phones to Raspberry Pi. you can take DSLR-like still images at the maximum resolution of 9152 x 6944. And with an autofocus lens, the ePTZ, and the upcoming continuous-autofocus features.
You now get more horsepower to build more applications, to cover more industries, to unlock more fields, at a much lower cost.
For seasoned makers, Pi Hawk-eye is designed to ensure you a smooth upgrade, it is compatible with everything you already have: the v1/v2 form-factor, the MIPI CSl-2 connection, the latest libcamera software, the standard tripod mount. etc.
Even if you are using Raspberry Pi for the first time, you can follow the hands-on guide without hassle.
Samples
Optical Size 1/1.7" 9.25mm Diagonal(7.4×5.55mm)
Focus Type Manual/Auto
Sensor Resolution 9152×6944
Color Filter Quad Bayer Coding(QBC)
Focus 8cm~INF
Focal Length 5.1mm
View Angle 84 Degrees (Diagonal)
Dimensions 25×24 mm
Sensor Output Formats RAW10
Video Modes (Camera Module)* 9152×[email protected], 8000×6000@3fps, 4624×3472@10fps, 3840×2160@20fps, 2312×1736@30fps, 1920×1080@60fps, 1280×720@120fps
Platform Output Formats JPEG/YUV/RGB/RAW10
Video Modes (on Raspberry Pi) 1080p30,720p60 and 640×480p60/90
Supported Platforms Raspberry Pi 5/4B/Pi 2/3/CM3/CM4/CM5/Zero W/Zero 2 W
Raspberry Pi OS bookworm/bullseye(32-bit/64-bit) 01/28/22 or later releases
*Only kernel version 6.1.21 and later support 48MP and PDAF
**Raspberry Pi 2/3/Zero W may not be able to enable 9152×6944 and 8000×6000 due to RAM, please make sure your platform has more than or equal to 1G of RAM.
Packing Including
  • 1 x 64MP-AF Camera Board
  • 1 x 15cm 22-22pin FPC Cable
  • 1 x 15cm 15-22pin FPC Cable
