5MP HDR USB Camera Module with Wide Angle M12 Lens for Windows, Linux, Android, and Mac OS , A5648S
5MP OV5648 USB Camera Module with Wide Angle M12 Lens and Single Microphone for Windows, Linux, Android, and Mac OS
B0454-1
  • Ultra HD: Based on 5MP OV5648 color image sensor.
  • Plug-n-Play: UVC-compliant, connect and play. No additional driver is needed.
  • Wide-Angle: Armed with a 95-degree horizontal view wide-angle M12 Lens
  • Manual Focus: The removeable M12 Lens allows you to manually adjust the focus.
  • Onboard ISP: Integrated hardware ISP. Support auto exposure, auto white balance, etc.
$39.99
This camera is based on 5MP OV5648 USB Camera Module. The max resolution&frame rate is 2592(H)x1944(V)@30fps. Besides, we have equiped the camera with Manual Focus M12 Lens. Arducam team is committed to creating more convenient and more efficient camera solutions. We have expanded the using scope of the image sensor, enabling the camera to realize your various projects. The camera is equipped with a 110°(D)x95°(H)x76°(V) M12 lens, allowing you to use it for more applications. It is compatible with Windows, Linux, Android, and Mac OS and No additional drivers are required.
  • Live streaming
  • Videoconference
  • Monitoring 3D printer
  • Dashcam
  • Ultra HD Resolution: This camera adopts the 5MP OV5648 Color COMS sensor for sharp images and accurate color reproduction.
  • Wide Angle: Assembled with a 95-degree horizontal view angle M12 lens with IR-cut filter, which provides a much wider Field of View compared to other lenses.
  • Frame Rates: MJPG 15fps@2592*1944/2048*1536/1600*1200; 30fps@1920*1080/1280*960/1280*720/1024*768/800*600/640*360/640*480; YUY2 2fps@2592*1944/2048*1536; 5fps@1920*1080; 7.5fps@1600*1200/1280*960; 10fps@1280*720/1024*768; 20fps@800*600; 30fps@640*360/640*480
  • Plug-n-Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Wide Applications: Highly recommended for the video surveillance system, live streaming, videoconference, dashcam, and other vision applications.
Sensor OV5648
Resolution 5MP
Shutter Type Rolling shutter
Optical Size 1/4"
Output Format MJPG/YUY2
Pixel Size 1.4um x 1.4um
Sensor Active Area 2592(H)x1944(V)
Frame Rate MJPG 15fps@2592*1944/2048*1536/1600*1200; 30fps@1920*1080/1280*960/1280*720/1024*768/800*600/640*360/640*480; YUY2 2fps@2592*1944/2048*1536; 5fps@1920*1080; 7.5fps@1600*1200/1280*960; 10fps@1280*720/1024*768; 20fps@800*600; 30fps@640*360/640*480
FOV 110°(D)x95°(H)x76°(V)
Lens Mount M12
F.NO 2.5±10%
E.F.L 2.1
IR Sensitivity Integral IR-cut filter, visible light only
TV Distortion <20%
Interface USB 2.0 device
Connector B4B-ZR
Operating Voltage DC 5V +/- 5%
Working Current Max 300mA
Operating Temp. -4°F-158°F(-20°C to 70°C)
Camera Board Size 38mm x 38mm
Audio Single Microphone
Supported OS Windows, Linux, Android, and Mac OS
Sample Application AMCap-Windows Camera application for Video and Still Capture
UVC Controls Brightness, Contrast, Saturation, Sharpness, White Balance, Gain
  • 1 x Arducam 5MP Wide Angle USB Camera Module
  • 1 x USB Cable (1m)
  • 1 x Quick start guide
  • No platform board (Raspberry Pi/Nvidia Jetson Nano/NX board) is included in the package
