5MP OV5648 USB Camera Module with Wide Angle M12 Lens and Single Microphone for Windows, Linux, Android, and Mac OS
Arducam 2MP Low Light USB Camera Module with M12 Pinhole Lens and Metal Holder
5MP HDR USB Camera Module with Wide Angle M12 Lens for Windows, Linux, Android, and Mac OS , A5648S
B045401
  • [Plug-and-Play] UVC-compliant, No additional driver is needed.
  • [HDR] Features the High Dynamic Range function.
  • [AI-Ready YUV Output] Supports YUV resolutions optimized for AI
  • [Low Distortion Wide-Angle] Armed with a low distortion wide-angle M12 Lens
  • Onboard ISP: Integrated hardware ISP. Support auto exposure, auto white balance, etc.
$38.99
The A5648S 5MP HDR USB Camera Module is a plug-and-play UVC solution compatible with Windows, Linux, Android, and macOS. It features High Dynamic Range (HDR) for clear imaging in challenging lighting and supports AI-friendly YUV resolutions for computer vision workflows. Equipped with a low-distortion 88° wide-angle M12 lens, it delivers broad, accurate scene coverage. The onboard hardware ISP provides auto exposure, auto white balance, and other image optimizations directly on the module for consistent, high-quality output.
  • Live streaming
  • Videoconference
  • Monitoring 3D printer
  • Dashcam
  • Plug-and-Play UVC Compatibility The A5648S is fully UVC-compliant, enabling seamless plug-and-play operation on Windows, Linux, Android, and macOS without any driver installation. It integrates easily into existing systems for rapid deployment.
  • High Dynamic Range (HDR) Equipped with HDR capability, the camera captures clear and detailed images in high-contrast environments. Bright and dark areas are preserved simultaneously, making it suitable for indoor, outdoor, or mixed-lighting applications.
  • AI-Optimized YUV Resolutions Designed for AI vision workloads, the camera supports a range of lightweight YUV resolutions ideal for edge inference, gesture detection, object recognition, and embedded CV tasks. Supported AI resolutions include: from 96 × 96 @ 30fps to 640 × 480 @ 30fps
  • Low-Distortion 88° Wide-Angle M12 Lens The integrated M12 lens offers an 88° wide horizontal field of view with low optical distortion, ensuring accurate scene capture for robotics, smart terminals, people detection, and other spatial-awareness applications.
  • Onboard Hardware ISP Featuring a built-in image signal processor, the A5648S delivers consistent, high-quality output with hardware-level enhancements.
General Sepcs B045401 B0454-1
Still Resolution 5MP 5MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/2.8'' 1/4"
Pixel Size 2 µm x 2 µm 1.4 µm x 1.4 µm
Sensor Active Area 2592(H)x1944(V) 2592(H)x1944(V)
Frame Rate MJPG: 2592*1944@30fps; 2048x1536@30fps;
1920x1080@30fps; 1600x1200@30fps;
1280x960@30fps; 1280x720@30fps;
1024x768@30fps; 800x600@30fps;
640x360@30fps; 640x480@30fps;
MJPG: 2592x1944@15fps, 2048x1536@15fps;
1600x1200@15fps, 1920x1080@30fps;
1280x960@30fps, 1280x720@30fps;
1024x768@30fps, 800x600@30fps;
640x360@30fps, 640x480@30fps;
YUY2: 2592x1944@2fps, 2048x1536@2fps;
1920x1080@5fps, [email protected];
[email protected], 1280x720@10fps;
1024x768@10fps, 800x600@20fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
Focus Type Fixed Focus Fixed Focus
FOV 101°(D)×88°(H)×60°(V) 110°(D)x95°(H)x76°(V)
Lens Mount M12-S M12-S
F.NO F2.8±5% F2.5±10%
E.F.L 2.7mm 2.1mm
Default Focus Range 300cm-∞ 300cm-∞
Distortion <-1.0% <20%
Operating Voltage DC 5V +/- 5% DC 5V +/- 5%
Power Consumption Typical: 1.043w Typical: 0.818W
Camera Board Size 32mm x 32mm x 1.6mm 38mm x 38mm x 1.6mm
HDR Support Yes NO
Supported OS Windows, Linux, Android Windows, Linux, Android
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Lowlight Compensation, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
  • 1 x Arducam 5MP Wide Angle USB Camera Module
  • 1 x USB Cable (1m)
  • 1 x Quick start guide
  • No platform board (Raspberry Pi/Nvidia Jetson Nano/NX board) is included in the package
