2MP  OV2710 1/2.7''  color CMOSsensor Standalone Camera UC2710-A25
Arducam 5MP OV5642 Camera Module /w CS mount Lens
Arducam 5MP OV5640D CMOS AF Camera Module 1/4-Inch Module
B0158
$24.99
ArduCAM now released a new 5MegaPixel AutoFocus CMOS camera module with JPEG output. The camera module is based on Omnivision OV5640 image sensor and can be used with ArduCAM shields and other platforms like Freescale i.MX6 develop board.
The OV5640 (color) image sensor is a low voltage, high-performance, 1/4-inch 5 megapixel CMOS image sensor that provides the full functionality of a single chip 5 megapixel (2592x1944) camera using OmniBSI™ technology in a small footprint package. It provides full-frame, sub-sampled, windowed or arbitrarily scaled 8-bit/10-bit images in various formats via the control of the Serial Camera Control Bus (SCCB) interface.
The OV5640 has an image array capable of operating at up to 15 frames per second (fps) in 5 megapixel resolution with complete user control over image quality, formatting and output data transfer. All required image processing functions, including exposure control, gamma, white balance, color saturation, hue control, defective pixel canceling, noise canceling, etc., are programmable through the SCCB interface or embedded microcontroller. The OV5640 also includes a compression engine for increased processing power. In addition, Omnivision image sensors use proprietary sensor technology to improve image quality by reducing or eliminating common lighting/electrical sources of image contamination, such as fixed pattern noise, smearing, etc., to produce a clean, fully stable, color image.
Features:
  • Cellular phones
  • PDAs
  • Toys
  • ARM based platforms
  • 1pcs CMOS OV5640D AF Camera Module 1/4-Inch 5-Megapixel Module
Documantation
5MP OV5640
Introduction Arducam AutoFocus OV5640 camera breakout incorporates Omnivision 1/4−inch CMOS active−pixel digital imaging sensor OV5640 with an active pixel array of 2592×1944. The entire system-on-a-chip (SOC) has onchip AEC/AGC/AWB etc ISP functions, and supports RAW/YUV/RGB/JPEG different output format. Key Specification Optical format 1/4−inch (4:3) Active pixels 2592 x 1944 Pixel size 1.4 x 1.4µm Color […]
User guide.pdf
Application Note.pdf
Arducam USB3.0 Camera Shield
GitHub
ArduCAM/RaspberryPi
Code Reference
You can purchase this item fromArducam distributors
