1 * ISX031 GMSL2 TX Camera
1 * 1m Fakra RF Coaxial Cable
1 * GMSL2 RX Deserializer Adapter Board
B0608-3
  • [8-Channel Camera Kit] Up to 8*camera setup for NVIDIA Jetson AGX Orin.
  • [Sony ISX031 Sensor] 3 MP with 120 dB HDR and LED Flicker Mitigation.
  • [GMSL2 Extension up to 15 m] High-speed, low-latency transmission over coaxial cable.
  • [IP67-Rated Cameras] Fully sealed for outdoor and industrial environments.
  • [Built-in ISP] Real-time hardware image processing for stable, vivid output.
$399.99
The 3MP ISX031 8-Channel GMSL2 Camera Kit brings together Sony’s high-performance ISX031 sensors and Arducam’s advanced GMSL2 extension technology to deliver a robust, long-range multi-camera solution for NVIDIA Jetson AGX Orin. Each camera module offers 120 dB HDR, LED Flicker Mitigation, and a built-in ISP, producing high-quality images even under extreme lighting conditions. With IP67 waterproof housings and coaxial extension support up to 15 m, this kit is engineered for outdoor robotics, autonomous vehicles, and industrial vision systems that demand reliability, clarity, and scalability.
    Autonomous vehicles and mobile robotics
  • Multi-camera perception and sensor fusion
  • Smart traffic and outdoor surveillance
  • Industrial and warehouse automation
  • AI vision systems on Jetson AGX Orin
  • ▶ 8-Channel Synchronized Imaging Supports up to eight ISX031 cameras connected simultaneously to NVIDIA Jetson AGX Orin, ideal for multi-view perception and 360° awareness applications.
  • ▶ GMSL2 Extension up to 15 m High-speed GMSL2 interface enables reliable, low-latency image transmission over a single coaxial cable — up to 15 meters. (Default kit includes eight 1 m coaxial cables.)
  • ▶ 120 dB High Dynamic Range (HDR) Captures precise details in both bright and dark regions, ensuring superior visibility in complex lighting environments.
  • ▶ Built-in Image Signal Processor (ISP) Per-camera hardware ISP handles color tuning, exposure control, and tone mapping, ensuring consistent image quality across all eight channels.
  • ▶ LED Flicker Mitigation (LFM) Minimizes flicker artifacts under LED or strobe lighting, making it ideal for traffic, warehouse, and smart-city applications.
  • ▶ IP67 Waterproof and Dustproof Design Each camera module is fully sealed to IP67 standards, offering dependable protection against dust, moisture, and weather exposure.
  • ▶ Designed for NVIDIA Jetson AGX Orin Native compatibility with Jetson AGX Orin for high-bandwidth multi-camera input, optimized for AI and autonomous vision workloads.
Sensor ISX031
Resolution 3 Megapixels
Chroma Color
Optical Format 1/2.42"
Pixel Size 3.0 µm x3.0 µm
Sensor Active Area 1920(H)×1536(V)
Resolution@fps 1920x1536@60fps
ISP Built-in ISP
FOV 152°(D)×120°(H)×92.8°(V)
Lens Mount M12
F.NO F2.2
E.F.L 3.0mm
Distrotion <-20%
Alignment Method Active Alignment (AA)
Camera Interface GMSL2
Connector FAKRA Connecter
Data Transmission Lanes 4-Lane
Output Format UYVY
HDR Support Yes
Supported JetPack Version JetPack 6.2.2 / L4T 36.5.0 and later
Supported Platform NVIDIA Jetson AGX Orin
Overall Weight (Net) 412g
Overall Size Camera Module: 23 x 23 x 31.45 mm
Deserializer Board: 93.2 x 58.3 mm
IP Rating IP67
Certification RoHS
  • The product supports streaming output by default. If you need to external trigger output, please contact Arducam Sales in advance for confirmation.
  • 1 x GMSL2 Rx Deserializer board
