1.58MP IMX296 Color Global Shutter Camera Module for DepthAI OAK
12MP IMX378 Camera Module with wide angle for DepthAI OAK
13MP IMX214 Camera Module for DepthAI OAK
B0422
  • High Resolution: 13MP
  • High Frame Rate: up to 35fps at Full HD
  • Easy to use: compatible with OAK FFC boards for evaluation
$15.99
PRODUCT DESCRIPTION
This Arducam IMX214 13MP high-resolution camera module is designed and released as the color camera in OAK Lite variants; OAK-D-Lite and OAK-1 Lite.It is also compatible with OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P), so you can easily evaluate its sensor and optics performance via a camera board and a flex cable.
SPECIFICATION
Sensor IMX214
Optical Size Type 1/3.1”
Pixel Size 1.12μm×1.12μm
Shutter Type Rolling Shutter
Color Filter Array RGB Color
Max Sensor Resolution 4224 x 3136
Resolution & Frame Rate 4224 x 3136@30fps, 4056×3040@30fps, 3840×2160@30fps, 1920×1080@35fps
Supported Platform OAK-D-Lite, OAK-1 Lite, OAK-FFC-3P, OAK-FFC-4P
Focus Type Manual
Focus 50cm~INF
Lens f/2.2, EFL: 3.37mm, FoV: 81.3° (D)
IR Sensitivity Build-in 650nm IR filter, sensitive to visible light only
Module Dimensions 8.5mm x 14.67mm
DOCUMENTATIONS
PACKING LIST
  • 1 x IMX214 Camera Module for DepthAI OAK
