13MP IMX214  Camera Module for DepthAI OAK
OV9282 Monochrome Global Shutter Camera Module for DepthAI OAK
12MP IMX378 Camera Module with wide angle for DepthAI OAK
B0416
  • High Resolution: 12MP
  • High Frame Rate: up to 60fps at Full HD
  • Easy to use: compatible with OAK FFC boards for evaluation
$29.99
PRODUCT DESCRIPTION
Sony's IMX378 is a 12MP (4056x3040) rolling shutter color image sensor. Arducam IMX378 camera module can be used in almost all of the OAK products (OAK-D, OAK-D S2, OAK-D Pro, OAK-D-PoE, OAK-D S2 PoE, etc.) as the color camera.
It is also compatible with OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P), so you can easily evaluate its sensor and optics performance via a camera board and a flex cable.
SPECIFICATION
Sensor IMX378
Optical Size Type 1/2.3”
Pixel Size 1.55μm×1.55μm (Diagonal 7.857 mm)
Shutter Type Rolling Shutter
Max Sensor Resolution 4056 x 3040
Color Filter Array Bayer RGB
Resolution and Frame Rate RAW10: 1332×990@120fps; RAW12: 2028×1080@50fps, 2028×1520@40fps, 4056×3040@10fps
Supported Platform Pi 4/3/Zero/CM3/CM4
Output RAW10/RAW12
Focus Type Fixed
Focus Distance 50cm~INF
Lens f/2.8; EFL: 2.75mm; FoV: 120° (D)
IR Sensitivity Built-in 650nm IR-cut filter, visible light only
Dimensions 25mm × 24mm
Documentations
Pack List
  • 1 x IMX378 Camera Module with wide angle for DepthAI OAK
