IMX477 camera modules have the high resolution.But traditional IMX477 cameras generally have larger camera boards and larger lenses. In order to make the IMX477 camera more convenient and space-saving, we have developed this camera based on the 477M image sensor. The 477M and IMX477 have exactly the same optical size and pixels, and the frame rate at different resolutions is also the same. We equipped a 1/2.3 inch 6p lens on this basis. The camera board is about 24x25mm, which makes it more flexible and convenient to move and transfer. Through the specially equipped lens and 477M sensor, we have achieved the compatibility of high pixel and tiny size.
| Still Resolution | 12.3 Megapixels |
| Video Modes | 2028 × 1080p50, 2028 × 1520p40 and 1332 × 990p120 |
| Sensor Resolution | 4056 x 3040 pixels |
| Sensor image area | 6.287mm x 4.712 mm (7.9mm diagonal) |
| Pixel Size | 1.55 µm x 1.55 µm |
| Optical Size | 1/2.3" |
| Supported Platform | Raspberry Pi 5/4B/3B+/3/2/CM3/CM4/CM5/Zero W/Zero 2 W |
| Focus Type | Fixed Focus |
| Focal Length | 2.75mm |
| F.NO | F2.8 |
| Field of View(FOV) | 120°(D) |
| Lens Mount | / |
| Camera Board Size | 25 × 24mm |
