Arducam Pivistation 5 Klarity, 20MP IMX283 All-in-one High Sensitivity Raspberry Pi 5 Camera Kit
Arducam KingKong, All-in-one Raspberry Pi CM4 AI Camera Kit
Arducam PiNSIGHT, 12MP Vision AI Mate for Raspberry Pi 5
B0505
    Explore Arducam's latest Pivistation 5, All-in-one Pi5 Camera. See the story on Kickstarter.
  • Intelligent Vision for Raspberry Pi
  • Cost-Effective AI Camera Solution
  • High Computing Power with Low Power Consumption
  • Easy Adaption and Assembly
  • Stylish Look and Shape
$99.99
Arducam PiNSIGHT is an AI marvel, seamlessly integrating with Raspberry Pi to create an intelligent vision hub. Its backward compatibility with Pi 4B/3B+ opens doors to limitless possibilities, transforming your Raspberry Pi into a visionary powerhouse for advanced AI applications.
The heart of PiNSIGHT lies in its collaboration with the cutting-edge OAK-SoM. With hardware-based encoding capabilities (H.264, H.265, MJPEG), this embedded system ensures superior efficiency and faster video processing. Paired with the Arducam 12MP camera module, it optimizes power consumption, providing a powerful yet energy-efficient solution for intelligent vision applications.
PiNSIGHT's 4K camera module takes visual clarity to new heights. With encoding support at 4K/30FPS and 1080P/60FPS, it delivers unparalleled performance. This hardware synergy not only guarantees real-time precision but also enables parallel processing for handling multiple video streams. PiNSIGHT empowers your Raspberry Pi with AI capabilities that redefine the boundaries of intelligent vision.
  • Face Recognition
  • Fatigue Detection
  • Object Recognition
  • Anomaly Detection
  • Pose Estimation Example
  • Seamless Integration: PiNSIGHT effortlessly transforms Raspberry Pi into an AI powerhouse, offering expanded possibilities for intelligent vision. It's backward compatible with Pi 4B/3B+.
  • OpenVINO Harmony: PiNSIGHT seamlessly integrates with OpenVINO, enabling flexible deployment of advanced AI capabilities in a diverse ecosystem.
  • Efficient Hardware Encoding: OAK-SoM enables hardware-based encoding (H.264, H.265, MJPEG), ensuring superior efficiency, faster video processing, and optimized power consumption when paired with the Arducam 12MP camera module.
  • High Performance, Low Power: PiNSIGHT delivers consistent real-time performance with dedicated hardware acceleration, ideal for power-constrained applications, supporting parallel processing of multiple video streams.
  • Simple and Affordable: PiNSIGHT's easy adaptation to Raspberry Pi 5, sleek design, and cost-effectiveness make it the prime choice for an excellent and budget-friendly AI camera solution.
Still Resolution 12.3 Megapixels
Video Modes 4056×3040@30fps, 3840×2160@30fps, 1920×1080@60fps
Output Format RAW10/YUV/NV12/RGB
Sensor Resolution 4056 x 3040 pixels
Sensor image area 6.287mm x 4.712 mm (7.9mm diagonal)
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
IR Sensitivity Integral IR-cut Filter, visible light only
Focus Type Auto Focus
Focal Length 4.81mm
F.NO F1.8
Field of View(FOV) 81°(D)×69°(H)×55°(V)
Lens Mount Stock Lens
Distortion <1%
Default Focus Range 15cm-∞
Overall Size 88.5×58×10 mm
Operating Temp. -20°C and 50°C
Power Requirements 5V 1A (Module Only)
  • 1× Arducam Pinsight AI Mate
  • 1× 15cm USB3.0 TyPE-C Cable
  • The Raspberry Pi Board is not included in the package.
  • Performance with Rpi 3 and below might be affected.
  • To ensure optimal performance, an official Raspberry Pi 27W power supply is recommended.
  • Other power supplies may cause the Pi 5 to limit downstream USB current. For power supplies under 27W, enable usb_max_current_enable=1. For power supplies with POE HAT, set PSU_MAX_CURRENT=5000.
