Arducam 1.3MP OG01A1B MONO Global Shutter USB 3.0 Camera Evaluation Kit
Arducam 0.3MP OG0VA1B MONO Global Shutter USB 3.0 Camera Evaluation Kit
EK041
  • Quick Evaluation: Ready-to-work camera & adapter bundle.
  • OG0VA1B has a high QE of 40% at 940 nm and 60% at 850 nm.
  • USB 3.0 Interface: Compatible with any hardware you choose.
  • Fixed Focus: Armed with a M12 low distortion fixed focus Lens.
  • SDK&API: Developer-friendly SDK& API for easy integration.
  • Note: The Camera Evaluation Kit needs a configuration file (sent via shipping notice) and isn’t plug-and-play.
$299.99
To help customers evaluate the cameras or build a prototype with your own circuits without dealing with fine pin pitch flex cable or soldering balls, Arducam has released the evaluation kit with camera breakout boards and Arducam USB2/USB3 camera shield without writing a single line of code.
The camera evaluation kit is based on a 0.3MP Mono Global Shutter OG0VA1B image sensor and equipped with an M12 fixed focus Lens. Meanwhile, accompanied by Arducam USB Camera Shield UI tools, it can achieve the adjustment of white balance, exposure, gain, and so on.
It comes with a VGA (640x480) camera module and our USB 3.0 camera adapter for you to build quick prototypes and proofs-of-concept with any backend hardware. The dev kit also comes with a complete SDK you can rely on to make easy integration into any machine vision applications. Arducam is committed to creating diverse and convenient camera solutions. For details, please refer to our official website www.arducam.com
  • Object Detection
  • In-cabin Monitoring
  • Automotive Driver System
  • Machine vision
  • ARM/FPGA/DSP-based platforms
  • High QE of 40% at 940 nm and 60% at 850 nm, based on B&W CMOS global shutter (GS) Image Sensor OG0VA1B.
  • 640 x 480 VGA resolution at 180 frames per second (fps) and 320 x 240 QVGA resolution at 360 fps.
  • Precise M12 Low Distortion Lens: Ensures sharpness and clarity in your captured images.
  • Fast USB 3.0 interface: Enjoy high-speed data transfer for seamless connectivity.
  • Convenient bundle: Ready-to-use camera and adapter package for quick evaluation and setup.
Specs
Resolution/Frame Rate 640x480@180fps, 320x240@360fps
Sensor Output Format RAW10
Exposure Control Range 10us-5555us  10us-2777us
Gain Control Range 1.0-15.0 Times
Color Filter Type Mono
Focal Length 3.6 mm
Field of View(FOV) 22°(D)×17°(H)×13°(V)
Distortion <-0.35%
IR Sensitivity No IR-cut filter
Power Consumption* Max: 1.03w  Min: 0.74w
Operation Temperature 0-50 ℃
Evaluation Kit Size 40mmx40mm
Functions
Image File Format DNG/JPEG
Software ISP Not Supported
Supported Programming Languages Python/C++
Supported OS Windows x86/x86_64
GUI(Graphical User Interface) Supported
Optional Items
Random Resolution These additional functions require customized services to be supported. Please contact sales for customization services.
Even Higher/Lower Frame Rate
More RAW Output Format Options(RAW10)
Long Exposure
External Trigger Mode
  • 1 x Arducam OG0VA1B USB3 Camera Kit with Back Cover and Tripod Mount
  • 1 x 1m USB3.0 Cable
  • You will need corresponding configuration files to use the camera kit on Arducam USB Camera Shield GUI, please contact sales for the files.
