Arducam OV7251 0.31MP Monochrome Global Shutter Camera Module for Raspberry Pi 5/4/3B+/3
Arducam OV9281 1MP Global Shutter NoIR Mono Camera with 130deg M12 Mount for Raspberry Pi
Arducam OV9281 1MP Monochrome Global Shutter Camera Module with M12 Mount lens for Raspberry Pi 5/4/3B+/3
B0165
  • Native to Raspberry Pi: Supported by the Raspberry Pi native driver
  • Easy to Use: Just enable the overlay to make it work
  • Global Shutter: Shoot high-speed moving objects in crisp sharp images
  • More Applications: Gesture detection, motion detection, eye tracking and so on
  • Wide Compatibility: Support Raspberry Pi 5, Pi 4, Pi 3/3B+/3A+, CM3/3+, Pi Zero and more
  • IR Sensitivity: NoIR, sensitive to IR light, available for night vision
$41.99
The Arducam monochrome (B&W) global shutter 1280x800 resolution OV9281 camera module is mainly designed for Raspberry Pi boards, and it can be connected directly to RPi’s CSI-2 camera interface without additional hardware.
The Arducam OV9281 camera breakout incorporates Omnivision 1/4-inch 1 Mp (1280×800) CMOS digital image sensor which is capable of operating at up to 60fps in 1MP ( 1280×800 ) resolution at 1-lane MIPI mode. The OV9281’s high frame rates make it an ideal solution for low-latency machine vision applications.
The sensor's global shutter and excellent low-light sensitivity allow it to be used for any application that needs gesture detection, head, and eye tracking, and depth and motion detection.
  • Security
  • High dynamic range imaging
  • Unattended surveillance
  • Stereo vision
  • Machine vision
  • Automation
  • USB 3.0 quick development and evaluation board is for sensors like OV9281.
  • For ReV.A, check Arducam driver; For Rev.B, check Raspberry Pi driver .
  • Monochrome global shutter Camera Module with M12 Mount lens directly inserts to CSI slot on Raspberry Pi. Support Raspberry Pi 5, Pi 4, Pi 3/3B+/3A+, CM3/3+, Pi Zero and more.
  • Supported By The Lastest Official Firmware: The Raspberry Pi has recently updated its firmware with V4L2 camera drivers, which adds support including for OV9281. Thus this OV9281 camera module is compatible with the official V4L2 camera driver, and you can get it working easily just by enabling the overlay
Sensor Monochrome Global Shutter OV9281
Sensor size 1/4”
Resolution 1MP 1280x800
Frame Rate RAW8: 640×400@309fps, 1280×720@171fps, 1280×800@143fps
RAW10: 640×400@247fps, 1280×720@137fps, 1280×800@114fps
Pixel Size 3 μm x 3 μm
Focal Length 2.8mm
F.NO 2.8
Focus Distance 30 cm to infinity
Field of View (FOV) 82°(D) x 70° (H) x 55°(V)
IR Sensitivity NoIR, sensitive to IR light
Output Format 8/10-bit BW RAW
Output Interface 2-lane MIPI serial output
Dimension 40mm x 40mm
Default Lens Low distortion M12 lens (Part Number: M27280M07S)
  • 1 x Arducam OV9281 1MP Monochrome Global Shutter Camera Module with low distortion M12 Mount Lens
  • 1 x 150mm 15pin 1.0mm to 22pin 0.5mm pitch FPC cable
  • 1 x 150mm 22pin 0.5mm pitch FPC cable
  • This camera and RPI driver doesn’t support hardware JPEG/H.264 encoding.
  • The official V4L2 driver only supports RAW data and manual exposure.
  • The lens on this camera is not interchangeable, if you need to replace the lens, please contact sales in advance!
    Raspberry Pi 5 √ √
raspberry pi global shutter camera blog thumbnail
Monochrome Global Shutter Cameras on RPi: OV7251 and OV9281 Camera Drivers Merged to Raspberry Pi Kernel
Many people perform computer and machine vision tasks on RPi, in which they have to deal with fast-moving objects. A global shutter camera is an ideal solution to avoid the rolling artifacts for better image processing, but it’s not easy on RPi. ​​​​​​​​​ ​​​​​​​​​Arducam is one of the first companies that offers a way to […]
GitHub
ArduCAM/MIPI_Camera
Selection Guide
Edit
