OAK-1 Lite
OAK-1 Lite
OAK-D W: OV9782×2+IMX378+Intel Movidius Myriad X for Depth AI OAK
OAK-D S2: OV9282×2+IMX378+Intel Movidius Myriad X for Depth AI OAK
OAK-D S2
$329.00
The OAK-D S2 is the series 2 of the OAK-D. The main difference is that OAK-D S2 has a smaller enclosure and is therefore lighter. OAK-D S2 also doesn’t have a barrel jack for supplying power, so it only has a USB-C connector for both power and communication.
Available in two variants:
    Both the Fixed-Focus and Auto-Focus variants have fixed-focus grayscale stereo cameras. The Auto-Focus vs. Fixed-Focus variants of OAK-D-Lite differ only in the 12.3 MP color camera. Fixed-Focus has the lens fixed in place mechanically and cannot move, whereas Auto-Focus has an electromagnet that controls the lens position dynamically.
    • Auto-Focus can focus on objects dynamically, which is mainly useful for objects within 50cm of the device. Auto-focus cameras can also be manually set to a specific focus position utilizing our API.
    • Fixed-Focus is recommended for heavy-vibration applications (e.g., drones, lawnmowers, bikes w/out suspension, etc. (see video)
      Both Auto-Focus and Fixed-Focus can clearly see objects beyond 50 cm, working between 50 cm and infinity. Auto-Focus has the advantage that it can focus on objects as close as 10cm (see video).
      Need a Wide FOV option? Check it out here: OAK-D W
      • 4 TOPS of processing power (1.4 TOPS for AI)
      • Run any AI model, even custom architectured/built ones
      • Encoding: H.264, H.265, MJPEG - 4K/30FPS, 1080P/60FPS
      • Computer vision: warp/dewarp, resize, crop, edge detection, feature tracking
      • Stereo depth perception at 120 FPS with filtering
      • Object tracking: 2D and 3D tracking
      • Dimension: 97x29.5x22.9 mm
      • Weight: 91g
      Camera Specifications
      Color camera Stereo pair
      Sensor IMX378 OV9282
      DFOV / HFOV / VFOV 81° / 69° / 55° 81° / 72° / 49°
      Resolution 12MP (4032x3040) 1MP (1280x800)
      Focus Auto-Focus: 8cm - ∞ Fixed-Focus: 19.6cm - ∞
      Max Framerate 60 FPS 120 FPS
      F-number 2.0 2.2
      Lens size 1/2.3 inch 1/4 inch
      Documentation:
      Includes:
      • OAK-D S2 camera
      • USB A-C cable
      Reference Numbers
      PN: OAK-D S2 Auto-Focus
      MN: A00498
      PN: OAK-D S2 Fixed-Focus
      MN: A00566
