The store will not work correctly when cookies are disabled.
JavaScript seems to be disabled in your browser.
For the best experience on our site, be sure to turn on Javascript in your browser.
NEW
Arducam IMX900 Series Camera Module —
Stereo · USB · GMSL Multi-Cam ,
built for Robotics , 3D Capture & In-Vehicle Vision .
Shop the Series
OAK-SoM MAX
OAK-SoM Pro (sets)
OAK-SoM Pro can be used to integrate the power of DepthAI into your own products, leveraging our open source software and hardware (see Github ).
OAK System on Module (SoM) allows integration into top-level systems with a need for a low-power, high-performance, real-time AI and depth perception.
Core digital electronics in the SoM include:
Movidius Myriad X VPU
64 MB QSPI NOR flash
32 kb I2C EEPROM
4 TOPS of processing power (1.4 TOPS for AI - RVC2 NN Performance)
Run any AI model, even custom architectured/built ones (models need to be converted)
Encoding: H.264, H.265, MJPEG - 4K/30FPS, 1080P/60FPS
Computer vision: warp (undistortion), resize, crop via ImageManip node, edge detection, feature tracking. You can also run custom CV functions
Stereo depth perception with filtering, post-processing, RGB-depth alignment, and high configurability
Dimensions: 30x45x4 mm
Weight: 5g
Interfaces with the system through two 10-gbps-rated 100-pin connectors (DF40C-100DP-0.4V(51))
Connectors: 2x 100-pin mezzanine connector with the same pinout as OAK-Som-Pro
MIPI lines: 2x 4-lane and 2x 2-lane MIPI RX lines
RAM: 1x DDR RAM due to size/shape constraints
Boot Modes Supported: NOR, eMMC, USB, Ethernet (EEPROM)
Supporting SD-card
USB 3.1 Gen 2
OAK-SoM-Pro (5pcs, box)
System on Module - 5 pcs
Heatsinks, screws, TIM
Official Technical Support
