OAK-FFC Kit is a set of extrusions and holders needed to build the mechanical scaffolding. You can now easily design a custom OAK module camera with chosen cameras and baselines (note: this version supports only OAK-FFC-4P base module).
Material
The particular parts are made of:
Screw: 304 stainless steel
Holder: SGCC
ALU Extrusion: 6061 Aluminum
Standoff on AR024 holder: 303 stainless steel
Standoff on small board holder: copper
1x hex key 1.5
1x hex key 2
1x hex key 4
2x ALU extrusion (long): 2cm x 2cm x 20cm
2x ALU extrusion (short): 2cm x 2cm x 10cm
6x FFC small board camera holder (horizontal baseline)
2x FFC small board camera holder (vertical baseline)
