OAK-D SR
OAK-D SR
OAK-1 Lite
OAK-1 Lite
OAK-D Pro W
OAK-D-Pro-W
  • 150° DFOV for stereo pair, 120° for central camera depending on variant chosen
  • Active stereo: IR dot projector improves depth perception, especially for low-visual-interest surfaces by projecting thousands of IR dots to the scene.
  • Night vision: IR illumination LED enables running your AI and CV algorithms in low-light or no-light environments
  • USB2 / USB3 for power delivery and communication
$529.00
OAK-D-Pro W is the ultimate camera for robotic vision that perceives the world like a human by combining a wide active stereo depth camera and wide high-resolution color camera with an on-device Neural Network inferencing and Computer Vision capabilities. It also features night vision for perceiving low-light and no-light environments.
Pro version is advised for application that require high-quality and reliable stereo depth perception in any kind of environment, including low-light, and texture-less scenes, where traditional passive stereo approach struggles.
Wide FOV allows you to capture more area in one shot, which can be especially useful for:
Multi-camera setup, to reduce the number of cameras needed to cover the whole area
AMRs, to cover larger area and to get more features for localization and 3D mapping - see VIO/SLAM documentation for more information
Object tracking/counting, for example vehicle or people counting over a larger area
  • 4 TOPS of processing power (1.4 TOPS for AI - RVC2 NN Performance)
  • Run any AI model, even custom architectured/built ones (models need to be converted)
  • Encoding: H.264, H.265, MJPEG - 4K/30FPS, 1080P/60FPS
  • Computer vision: warp (undistortion), resize, crop via ImageManip node, edge detection, feature tracking. You can also run custom CV functions
  • Stereo depth perception with filtering, post-processing, RGB-depth alignment, and high configurability
Central RGB Camera
Sensor IMX378
DFOV / HFOV / VFOV 120° / 95° / 70°
Resolution 12MP (4056x3040)
Focus FF: 60cm - ∞
Max Framerate 60 FPS
Stereo Pair Cameras
Sensor OV9282
DFOV / HFOV / VFOV 150° / 127° / 79.5°
Resolution 1MP (1280x800)
Focus FF: 18 cm - ∞
Max Framerate 120 FPS
  • OAK-D Pro W camera
  • Cable USB-CA-1m
  • Y-Adapter
Official Technical Support
