[Discontinued] Arducam Stereo USB Camera, Synchronized Visible Light and Infrared Camera, 2MP 1080P Day and Night Mini UVC USB2.0 Webcam
[Discontinued] Arducam IoTai ESP32 CAM WiFi Bluetooth PSRAM Development Board with Camera Module OV2640
[Discontinued] Multi Camera Adapter Doubleplexer Stereo Module V2 for Raspberry Pi CameraV3, Raspberry Pi Zero, Pi5/4/3B+/3
B016601
  • Multi-Camera Solution: Designed mainly for Raspberry pi ZERO, up to two 5MP OV5647/8MP IMX219/ 12.3MP IMX477/12MP IMX708 cameras connected. No mixing allowed.
  • Alternative Work: Only one of the two cameras can be activated at a time, and they are working in alternate ways.
  • Easy to Operate: A simple software built to run two cameras.
  • Compatibility: It also can be used for other Raspberry Pi boards with minor software modifications.
$29.99
This multi-camera adapter board is designed for Raspberry pi ZERO and allows you connect two 5MP or 8MP or 12MP cameras to Pi Zero. Only one of the two cameras can be activated at a time, and they are working in alternate ways. We build a simple software that can run two cameras and make it looks like working at the same time. But the drawback is the frame rate, and resolution will be fairly low, which may be mainly useful for surveillance.
Please note that the Raspberry Pi multi-camera adapter board is a nascent product that may have some stability issues and limitations because of the cable’s signal integrity and RPi's closed source video core libraries, so your project may get some risks. This version supports the 8MP Pi camera board. And it also can be used for other Raspberry Pi boards with minor software modifications.
  • IoT cameras
  • Robot cameras
  • Wildlife cameras
  • 3D scanner, multi camera sync solution, etc.
  • Fit Raspberry Pi zero to connect 2 x 5MP or 8MP or 12MP cameras.
  • Only one of the two cameras can be activated at a time, and they are working in alternate ways.
  • A simple software built to run two cameras and make it looks like working at the same time.
  • It also can be used for other Raspberry Pi boards with minor software modifications.
  • 1 x Arducam Multi-Camera Adapter Doubleplexer Stereo Module V2 for Raspberry Pi Zero, Pi 3/3 b+, 4b, 5
  • 1 x 73mm 15-22pin FPC cable
    • The default usage of this product is taking still pictures, and when it is used to store videos, the frame rate will be reduced.
Raspberry Pi 5
⚠️ Raspberry Pi Touch Display (DSI interface) Compatibility Issues
When you use a DSI display together with this adapter, you will encounter the issue of I2C conflicts. We recommend you use HDMI displays or run headless when using this adapter.
⚠️ Camera Module Compatibility
The Arducam Multi-camera adapters ONLY support 3 kinds of camera modules by default:
  • 5MP OV5647 (V1.3)
  • 8MP IMX219 (V2.1)
  • 12MP IMX477 (HQ)
  • 12MP IMX708(Raspberry Pi Camera Module 3)
ALL other MIPI camera modules intended to be used with Arducam multi-camera adapters needs extra customization. Extra fees may occur.
⚠️ Resolution and Framerate Compatibility
If you need the cameras to run at a certain resolution or framerates, please request customization. Extra fees may occur.
arducam-multi-camera-multiplexer-raspberry-pi-4-blog-thumbnail
Camera Multiplexer for Raspberry Pi 4: Arducam Solutions for Your Applications, and the Coming Surprises We Prepare for You
Introduction – What stops you from using dual cameras on the Raspberry Pi? Many of the Raspberry Pi users may notice that there is only one camera slot on the board. Actually, the processors on the latest Raspberry Pi models, like the Pi 3 and Pi 4, offer support for two cameras, but only one […]
17 comments
robot fish swarm with arducam multiplexer inside blog thumbnail
Blueswarm: Decentralized Robotic Fish Swarm Together Which uses Arducam Multi-camera Adapter and Raspberry Pi
The natural world abounds with self-organizing collectives, where large numbers of relatively simple agents use local interactions to produce impressive global behaviors. Well-known examples include social insect colonies, bird flocks, and fish schools. Mathematicians and engineers have strived to understand the mapping from local interactions onto global behaviors and vice versa in a quest to […]
Stereo Camera Adapter for Pi Zero
INTRODUCTION This multi-camera adapter board is designed for Raspberry pi ZERO and let you connect two 5MP or 8MP cameras to Pi Zero. Only one of the two cameras can be activated at a time, and they are working in alternate ways. It cannot run two cameras at the same time, but we build a […]
3D drawing
user guide
GitHub
ArduCAM/RaspberryPi
