Arducam OV7251 0.31MP Monochrome Global Shutter Camera Module for Raspberry Pi NoIR
OV9281 Monochrome Global Shutter 1MP Camera Module for Raspberry Pi
OV9281 Monochrome Global Shutter 1MP Wide Angle Camera Module for Raspberry Pi
B0405
  • Global shutter: up to 309fps
  • Monochrome: more sensitive to light
  • Wide angle: 150° (DFoV)
  • Mini size: 24x25mm, V1/V2 size
  • Easy to use: compatible with all Raspberry Pi boards
$35.99
Based on OmniVision's OV9281 high-speed global shutter image sensor, Arducam OV9281 camera module is released for the Raspberry Pi family. It is compatible with any existing Pi model and works well with the latest software from the foundation.
Features best-in-class near-infrared (NIR), and quantum efficiency (QE), a wider angle lens, and a V2-like form factor, it can meet high-resolution and low-latency requirements and is widely used in consumer and industrial computer vision applications, including augmented reality (AR), virtual reality (VR), collision avoidance in drones, bar code scanning and factory automation or etc.
Sensor OV9281
Optical Size Type 1/4''
Pixel Size 3μm×3μm
Shutter Type Global Shutter
Max Sensor Resolution 1280 x 800
Color Filter Array None (Monochrome)
Resolution and Frame Rate RAW8: 640×400@309fps, 1280×720@171fps, 1280×800@143fps
RAW10: 640×400@247fps, 1280×720@137fps, 1280×800@114fps
Supported Platform Pi 4/3/Zero/CM3/CM4
Output RAW8/RAW10
Focus Type Fixed
Focus Distance 50cm~INF
Lens f/2.0; EFL: 1.69mm; FoV: 150° (D)
IR Sensitivity build-in 650nm IR-cut filter, sensitive to visible light only
Dimensions 25mm × 24mm
Raspberry Pi 5 √ √
Packing Including
  • 1 x Arducam OV9281 Camera Module for Pi
  • 1 x 150mm 15pin to 22pin Ribbon Flex Cable
  • 1 x 80mm 22pin Ribbon Flex Cable
