Mega 5MP SPI Camera Module with M12 Lens (NoIR) for Any Microcontroller
Mega 3MP SPI Camera Module with M12 Lens (NoIR) for Any Microcontroller
Mega 5MP SPI Camera Module with M12 Lens for Any Microcontroller
B0436
  • Super Easy Using: High-level commands built-in, easy as a DSLR
  • Quick Response & Power Saving: 94ms wake-up and consumption low as under 200mW
  • Sharp Image: 5MP Resolution which can capture clearer and shaper images
  • Wide Compatibility: Compatible with any Microcontroller with a single standard SPI interface
  • Out of stock, check new version B043601
arducam shipping payment 1
$39.99
Arducam Mega 5MP Rolling Shutter camera is the latest product developed by Arducam Team. The Ultra High Stability&Accuracy and Open Source API of this camera can realize your project more effectively.
Arducam team is committed to creating more convenient and more efficient camera solutions. We have expanded the using scope of the image sensor, enabling the camera to realize your various projects.
The camera is featured Low Power Consumption and Super Sharp Image. Different from the Standard Mega 5MP Camera, we equip the camera with a Low Distortion M12 Lens (TV Distortion<1.53%).
  • Assets Monitoring
  • Space Journey
  • Environmental Observation
  • Dynamics Capture
  • loT Automation
  • Easy Using: Extremely easy to use. High-level commands were built in so you manipulate the camera through API access like using a DSLR camera via button clicks.
  • Low Distortion M12 Lens: Equipped with an Low Distortion M12 Lens with 75-degree HFOV by default.
  • Multiplexing: Up to 4 cameras running on a single MCU by using an adapter board. They capture at the same time with sequential readout then.
  • Open Source SDK: The SDK is fully open-source with MIT license. A lean architecture with a hardware abstraction layer, enabling you to add a new MCU without effort.
  • One Fits All: It fits any microcontroller with a single standard SPI interface (either native or mimic). 8-bit, 16-bit, or 32-bit, ARM, RISC-V, or others. Arduino, STM8/STM32, ESP8266/ESP32, MSP430, Nordic, Renesas, and countless more.
Product Series Arducam Mega
Optical Size 1/4''
Speed 8Mhz
Number of effective pixels 2592x1944
Power Supply 3.3V/5V
Interface SPI(4-wire)
Shutter Type Rolling Shutter
Color Filter Type Color
Output Format RGB/YUV/JPEG
Field of View 90°(D)x75°(H)x56.4°(V)
EFL 2.8mm
BFL 2.6mm
IR Sensitivity Integral IR-cut filter, visible light only
Focus Distance 0.8m-INF
Power Consumption(idle/Working) max 0.3w/1.58w
Electric Current (Idle/Working) max 63mA/316mA
Connector No. XH2.54-6P
Overall Size 33×33×35mm
  • 1 x Arducam Mega 5MP SPI Camera with M12 Lens
  • 1 x 300mm 6pin cable
  • No MCU board (Arduino, STM8/STM32, ESP8266/ESP32, Rpi Pico, etc) is included in the package
  • Arducam Mega Camera can be used on any Microcontroller board, but note that you will need the corresponding code and software to use it, please refer to the following documentation for details.
  • To protect the optimized focus achieved at the factory, the lens is fixed with adhesive. If you need to install a different M12 lens, please remove the existing adhesive first to avoid damage to the module.
