Sony's IMX378 is a 12MP (4056x3040) rolling shutter color image sensor. Arducam IMX378 camera module can be used in almost all OAK products (OAK-D, OAK-D S2, OAK-D Pro, OAK-D-PoE, OAK-D S2 PoE, etc.) as the color camera.
It is also compatible with OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P), so you can easily evaluate its sensor and optics performance via a camera board and a flex cable.
Specification
IMX378
Optical Size
Type 1/2.3'' (Diagonal 7.857 mm)
Pixel Size
1.55μm×1.55μm
Rolling Shutter
Color Filter Array
Bayer RGB
Max Sensor Resolution
4056 x 3040
Resolution and Frame Rate
4056x3040@30fps, 3840x2160@30fps, 1920x1080@60fps
Supported Platform
OAK D series (OAK-D, OAK-D S2, OAK-D Pro, OAK-D-PoE, OAK-D S2 PoE, etc.) and OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P)
1 x IMX378 Autofocus Camera Module for DepthAI OAK
