OV9282 Monochrome Global Shutter Camera Module for DepthAI OAK
12MP IMX378 Camera Module for DepthAI OAK
IMX214 13MP Camera Module for DepthAI OAK
B0417
  • High Resolution: 13MP
  • High Frame Rate: up to 35fps at Full HD
  • Easy to use: compatible with OAK FFC boards for evaluation
$19.99
This Arducam IMX214 13MP high-resolution camera module is designed and released as the color camera in OAK Lite variants; OAK-D-Lite and OAK-1 Lite. It is also compatible with OAK FFC boards (OAK-FFC-3P, OAK-FFC-4P), so you can easily evaluate its sensor and optics performance via a camera board and a flex cable
Sensor IMX214
Optical Size Type 1/3.06''
Pixel Size 1.12μm×1.12μm
Shutter Type Rolling Shutter
Color Filter Array RGB Color
Max Sensor Resolution 4208 x 3120
Resolution & Frame Rate 4208x3120@30fps, 4056x3040@30fps, 3840x2160@30fps, 1920x1080@35fps
Supported Platform OAK-D-Lite, OAK-1 Lite, OAK-FFC-3P, OAK-FFC-4P
Focus Type Autofocus
Focus Distance 50cm~INF
Lens f/2.2, EFL: 3.37mm, FoV: 81.3° (D)
IR Sensitivity Build-in IR filter, sensitive to visible light
Module Dimensions 8.5mm × 14.67mm
Packing Including
  • 1 x IMX214 Camera Module for DepthAI OAK
