2MP GC2145 Color DVP Camera Module for Arduino GIGA R1 WIFI Board
HM01B0 QVGA Monochrome DVP Camera Module for Arduino GIGA R1 WIFI Board
HM0360 VGA Monochrome DVP Camera Module for Arduino GIGA R1 WIFI Board
B0461
  • Efficient & Compact & Ultra-Low Power Consumption MCU Solution.
  • Arduino® GIGA Display Shield and GIGA R1 WIFI Board Compatible.
  • Simple for All: Set up and access with simple operations.
  • High Precision: Strong power for precise visual analysis.
  • Low Consumption: Low power consumption to save more.
$9.99
The camera module is based on HM0360 VGA image sensor, which is an ultralow power, Back Side Illuminated (BSI) CMOS sensor designed for energy efficient smart vision applications, such as object-specific classification, tracking, and identification. The VGA resolution is ideal for monitoring, detection and image capture for wide field of view camera devices.
The low consumption camera module is equipped with a 64°(DFOV) stock Lens. It supports 8-bit RAW output format. The standrad operating temperature is between -30~85℃, with the stable Image temp. between 0~50℃.
Fully compatible with the Arduino GIGA R1 board and Arduino® GIGA Display Shield, a recent addition to Arduino's professional-grade microcontroller development boards. Seamless integration empowers the camera module, unlocking versatile image capture and processing capabilities. Leverage the combined strength of this camera module and Arduino GIGA R1 with GIGA Display Shield for a competitive edge in your projects.
  • Machine/Computer Vision
  • Robotics
  • IoT
  • Digital Fabrication
  • Real-time Processing
  • Cost-Effective Vision Solution: Affordable and compact, ideal for budget-friendly projects integrating vision capabilities.
  • Wide Compatibility: Pair with the GIGA Display Shield (not included) for an intuitive interface, simplifying camera setup and real-time monitoring.
  • Simplify Embedded Vision for All: Easy to set up and operate. Making it possible to add machine vision to your GIGA R1 board without much effort at all.
  • High Precision: With on chip high precision oscillator, Bad Pixel correction(BPC), auto exposure/gain, amblent light sensor and zone detection
  • Low Power Consumption: Efficient power usage, making it suitable for battery-powered and energy-efficient applications.
Image Sensor HM0360
Resolution VGA
Optical Size 1/6''
Number of effective pixels 640(H) × 480(V)
Pixel Size 3.6μm × 3.6μm
Support Platform Arduino GIGA R1 WIFI Board
Shutter Type Electronic Rolling Shutter
Color Filter Array Monochrome
Frame Rate 640x480@15fps, 320x240/160x120@30fps
Output Format RAW8/RAW4
F.NO 2.8±5%
Focal Length 2.59mm
Field of View(FOV) 64°(D)
Power Supply AVDD: 2.8V; DOVDD: 1.8V; DVDD: 1.2V
Operating Temperature -30~85℃
Camera Board Size 30.5mm x 30.5mm
  • 1 x Arducam VGA HM0360 Camera Module with 20-pin DVP Camera Board
  • No platform board is included in the package
