Global Shutter Camera for Raspberry Pi
The global shutter technology allows you to reduce or eliminate unwanted image artifacts, which occur with traditional rolling shutter image sensors as a result of motion during image capture. The sensor’s global shutter and excellent low-light sensitivity allow it to be used for any application that needs gesture detection, head/eye tracking, and depth and motion detection.
01 3
02 3
03 3
04 3
OV7251 Camera Module(0.3MP)
● Based on 0.3MP OV7251 Monochrome Image Sensor.
● Mainly designed for the Raspberry Pi and connected directly to its CSI connector.
● Support the official V4L2 camera driver and Arducam userland driver.
06
07
OV9281/0V9782 Cameras(1MP)
● Based on 1MP OV9281/OV9782 Image Sensor.
● Monochrome(OV9281) and color(OV9782) camera modules for your choice.
● Incorporating Omnivision 1/4-inch 1 Mp  (1280×800) CMOS digital image sensor which is capable of operating at up to 60fps in 1MP ( 1280×800 ) resolution at 1-lane MIPI mode.
OV2311 Camera Module(2MP)
● Based on 1/2.9-inch Monochrome OV2311 Image Sensor.
● Mainly designed for Raspberry pi boards, and it can be connected directly to RPi’s CSI-2 camera interface without additional hardware.
● Gaze and eye-tracking capabilities, achieve high near-infrared quantum efficiency to minimize active illumination power and reduce the system power requirements.
08
09
OG02B10 Camera Module(2MP)
● Based on 2MP OG02B10 Color Image Sensor.
● Owing an external trigger function, which is used to capture the image and helps in synchronized streaming by connecting two or multiple cameras.
● Adopting Pivariety driver with ISP processing function.
AR0234 Camera Module(2.3MP)
● Based on 2.3MP AR0234 Color Image Sensor.
● Adopt Pivariety driver with ISP processing function.
10
customization for raspberry pi cameras
  • Support for any sensors.
  • Well tuned ISP effects for RPi.
  • Custom lens and filter options.
  • Tailored module form-factor.
  • Customizable cable length, shape and pinout.
  • Camera housing design using CNC/Injection molding.
  • IP6x waterproof and anti-fog solutions.
