Arducam V3Link
Cameras
Build V3Link-based cost-effective camera solutions with seamless integrations for your systems and applications.
fpd link III or V3 camera solution
Arducam V3Link Cameras
The Power of TI’s V3Link Interface
As an industrial variant of FPD-Link III, V3Link is a multi-protocol physical layer technology that aggregates data from different industry standard protocols and transfers it over coaxial or twisted pair cables. It acts as a bridge between protocol-based data interfaces that transfer high bandwidth data over short distances, and in cases where the source interface does not match the sync interface, it can also work as a data converter.
The Power of Arducam & TI’s V3Link Solutions
Arducam consistently collaborates with Texas Instrument’s engineering team to provide you with the most adaptable, on-demand V3Link camera systems for various industrial applications.
Works w/ The Arducam MIPI Camera Portfolio
So you can use it with any of the Arducam MIPI CSI-2 cameras.
Instead of creating camera bundles, we want you to make your own kits that best suit your budget and application. The V3Link serializer board we designed is compatible with our entire collection of more than 100+ off-the-shelf modules encompassing various resolutions, lens types, frame rates, pixel sizes, sensor & shutter types.
fpd link III camera solutions 2
fpd link III camera solutions 3
Up to 15M Cable Length
For smaller footprints and flexible deployments.
Having longer cable lengths brings more benifits, especially for applications that not only require a high speed connection but also need to keep the camera as compact as possible and place it in constrained spaces far away from the hosts. Our V3Link solutions offers a stable cable connection of up to 15 meters on all 4 camera channels.
Multi-Camera Systems for Any Use Case
Giving everyone the freedom to create synchronized 4-channel vision systems.
Quad-camera systems where you get to control the specs will significantly drive the cost down for a wide range of automotive, surveillance, medical and industrial imaging applications, as our main focus, we strive to make the process easy for system developers.
fpd link III camera solutions 4
fpd link III camera solutions 1
Customizable in Every Way,
for Any Platform
Solutions that are tailored only for you, your platform, and your project.
Out of our ready-to-work camera collection, you can also make a custom-built system and decide on every aspect of the cameras (sensors, lenses, carrier boards, enclosures, etc.). We designed our V3Link solution to make sure that, whether you’ve got a popular embedded platform (Raspberry Pi, Nvidia Jetson, TI Eval. boards, etc.), or a specific dev board for a lesser-known industry, the support is already in place.
V3Link Camera Extension Solution for Raspberry Pi
Boasting all kinds of sensors following the V3Link protocol, ideal for high-bandwidth, extended-range projects.
Shielded coaxial cable ensures reliable power and data transmission up to 10m, ensuring low latency for peak performance.
Seamlessly integrating with Raspberry Pi 4B and Raspberry Pi 5, Arducam’s V3Link kit requires no additional drivers or configuration, ensuring worry-free compatibility.
Arducam wiki 64mp v3link test 1
Arducam website landing page v3link nvidia part
V3Link Camera Extension Solution for NVIDIA Jetson Orin Series
Arducam’s V3Link Camera Kit for NVIDIA Jetson Orin Series is built around a high-quality IMX477P sensor that adheres to the V3Link protocol, making it perfect for high-bandwidth, extended-range projects. With support for up to 2x IMX477P cameras and channel-switching capabilities, this kit is a versatile solution for various applications.
Designed for the NVIDIA Jetson Orin Nano/NX, the kit includes an IMX477P camera module with a pre-installed Tx board, a Rx adapter board for connecting to the Jetson development board, and a 1-meter coaxial cable, enabling remote camera deployment with minimal configuration.
V3Link + USB UVC Protocol Camera Extension Solution
Arducam unveils its latest breakthrough by integrating FPD V3LINK with USB 3.0 cameras. Harnessing the unique extension capabilities of FPD V3LINK technology, this cutting-edge solution empowers users with unmatched flexibility in extending USB cameras.
Central to the kit is the formidable IMX519 16MP camera, ensuring superior imaging performance. It seamlessly supports the output of YUY2 uncompressed format, delivering crystal-clear and highly detailed images. Moreover, the kit facilitates the connection of up to two identical IMX519 cameras, catering to versatile applications, particularly in the realm of Automotive ADAS.
Arducam website landing page v3link uvc part
Arducam website v3link picture contactus sensor 1
Contact Us for More Sensor Support
Arducam V3link camera solution is able to adapt to other image sensors not limited to IMX219.
Whether it’s TI, or the Raspberry Pi platform, we can be sure that whether you’ve got a popular image sensor or a specific sensor for a lesser-known industry, the support is already in place.
If you do have such needs, please contact us directly and we will do our best to meet your requirements.
Get V3Link Cameras for Your Application
FAQs
What’s the difference between V3Link and FPD Link-III?
V3Link is the industrial version of FPD Link III, it uses the same video over the coax standard, and you can consider it the automotive equivalent.
Does the kit come with camera modules?
Yes. Currently we have launched the IMX219 camera kit, and we will launch more camera combinations in the future.
Does the kit support external triggers?
Yes.
Can I pick one of your existing cameras but replace the lens with a different type of mount or FoV?
Yes. you can even have a customized carrier board in specific sizes.
Does the kit come with FPD-Link 3 cables?
Yes, it is equipped with FAKRA Cables using FPD Link III interface standard.
Can I use different cameras in one setup?
Customization is required, but yes.
What platforms does it support?
Systems we’ve already supported: Raspberry Pi, TI development boards. For other systems, simple talk to us.
