Introducing Arducam’s Partnership with ams OSRAM
Empowering Visions, Illuminating Collaborations
● Global leader in intelligent sensors and emitters
● LED, 3D ToF sensing, chip-packaging, VCSELs
● Capacitive sensing, CMOS imaging, Position sensing, Spectral sensing
Bringing intelligence to light and passion to innovation, ams OSRAM enriches people’s lives. ams OSRAM continuously advances its industry-leading technologies in sensing, illumination and visualization to make the world safer, simpler and more efficient. ams OSRAM is #2 in the global LED market (Trendforce 2022); #2 in Light Sensors (OMDIA 2021) and holds a leading position in the Automotive lamps/bulbs aftermarket.
● Proprietary flexible ISP technology
● Highly abstracted embedded camera architecture
● Advanced embedded image sensor packaging technology
Arducam, an emerging force in the imaging solutions sector, is dedicated to simplifying embedded vision hardware. Renowned for crafting advanced camera modules and evaluation kits, Arducam leads the way in pioneering developments, addressing the varied requirements of industries and makers. Positioned as a premier provider of embedded vision solutions, Arducam has proudly served over 2,000 commercial clients since 2012.
Mira220, the starting point.
● NIR enhanced with high sensitivity
● On-chip noise reduction
● Reduced off-chip processing
● Extended battery operation
● Ideal in low light conditions
The new Mira220 global shutter image sensor from ams OSRAM advances 2D and 3D sensing with high quantum efficiency at visible and NIR wavelengths
Mira Sensor Family
We help demonstrate how strong the Mira220 is.
Our journey with ams OSRAM commences with the groundbreaking Mira220 sensor. Utilizing the Arducam Mira Series NIR Enhanced USB3.0 Eval. Kit, we unleash the complete potential of the Mira220, allowing you to effortlessly witness the transformative DIFFERENCE it brings.
Arducam Mira Seires NIR Enhanced USB3.0 Eval. Kit
● Exceptional Performance in 940nm. ams Mira220’s stellar efficiency, and low power consumption.
● Compact Powerhouse: Ideal for space-limited, power-constrained, low-light applications.
● Crystal-Clear Imaging: Global shutter, Arducam’s M12 lens for impeccable clarity.
● User-Friendly Interface: Streamlined experience with a friendly interface and comprehensive SDK.
● Customization Options: Tailor EVK to your needs with sensor, lens, and form factor choices.
● Revolutionize Development: Accelerate POC, minimize time, receive expert assistance.
The DIFFERENCE comes from …
High Quantum Efficiency (QE)
Hence …
High Sensitivity
Optimal image quality in low-light
Unlock more features of Mira220
2.2MP Global Shutter
Swift and True
High Frame Rate
Ideal for high speed industrial applications
Experience seamless imaging for high-speed industrial applications with the Mira220’s high frame rate. Capable of reaching 90 fps at full resolution and bit depth, it ensures sharp, accurate captures of dynamic scenes. Ideal for scenarios where precision in motion is crucial, the Mira220’s swift frame rate opens new possibilities in industrial imaging.
Low-Power Consumption
Cost down with efficiency up
Why Arducam Eval. Kit?
Arducam Mira220 EVK: Beyond the Basics
Diverse Lens Options
Arducam’s Mira220 Series EVK presents a versatile imaging solution with the inclusion of diverse lens options. This feature provides unparalleled flexibility, allowing users to tailor their setups to specific needs and applications. From wide-angle to telephoto, the array of lens choices ensures that your imaging requirements are not only met but exceeded. Experience a new level of adaptability in capturing the world with Arducam’s Mira220 Series EVK.
Comprehensive SDK
Optimize your development process with the Arducam EVK’s Comprehensive SDK. Leverage the robust Python/C++ programming support to unleash the full potential of your projects. From prototyping to implementation, our SDK provides the tools you need for seamless integration and accelerated development.
Customization: Tailor Your EVK to Perfection
Unlock unparalleled flexibility with the Arducam EVK’s Customization feature. Craft a solution that meets your unique needs by choosing from a diverse array of image sensors, lens options, and form factors. Whether you’re pursuing innovation in image capture or addressing specific project requirements, customization ensures your Arducam EVK aligns perfectly with your vision.
Customization Examples
Customer Case 1: AI Sensing
Innovating in the realm of 3D sensing, one of our customers leverages Arducam’s advanced camera solution, which uses 2 x mono Mira220 and 1 x RGB Mira220 sensors. Arducam’s commitment to customization shines through, as the solution is tailored to meet the specific needs of this visionary application.
Customer Case 2: Security and Safety
